1040 antenna
mirehteshamali
Level 3
Level 3
i am confused with 1040 access point  does it comes with integared antenna or do i need to get a seprate one
here it says integrated antenna
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps11203/data_sheet_c78-609338.html
but at model comparison page , it says we need to get a seprate antenna
http://www.cisco.com/en/US/products/hw/wireless/products_category_buyers_guide.html
5 Replies 5
Surendra BG
1040 comes with a Integrated Antenna.. I guess the second link is the documentation error!! lemme speak with the documentation team..
Surendra
please dont forget to rate the usefull posts.
Surendra BG
Thanks surandera
A personal request , kind suggest or upload a document describing " how to choose an antenna or access point ie factors that comes into play "
power supplies ., connectors , regulatory compiance etc
please note that " cisco product  quick refrence guide " dosent mention 1040 series access points.
Is this wat you are looking for??
http://www.cisco.com/en/US/partner/docs/wireless/access_point/1040/quick/guide/ap1040getstart.html
Surendra
Surendra BG
Hi surendra ,
when i click the link it says " forbidden application "
plz check the link
I am able to open the link and this link requires your CCO ID and password login..
Surendra
Surendra BG
