04-22-2011 10:27 AM - edited 07-03-2021 08:07 PM
I've looked thru the various screens but I have not found anywhere to change the Timeout value on the login to Web Management of my 1041 Access Point. Is that definable?
It seems like if you pause for any amount of time, you have to login again before you can do anything. The time window is just annoyingly small and I want to bump it up to something else.
Mark
04-22-2011 10:34 AM
its not definable on the Autonomous AP, but its der on the WLC though!!
Here is the command reference guide, we do not have a command to do the same
Lemme know if this answerd ur question!!
Surendra
04-22-2011 10:43 AM
Getting a "Forbidden File or Application" page when I try to go to that link even after successfully logging to the Support site.
04-22-2011 10:46 AM
Thats a partner link.. guess that needs a valid username and password!!
Check this
Just checked in my device as well, we cannot do it
lemme know if this answered ur question..
Surendra
04-22-2011 10:45 AM
BTW -- the 1041 AP is a stand alone AP.
04-22-2011 10:47 AM
Yup i came to that know ur using that in Standalone mode!!
04-22-2011 11:40 AM
You need to do it thru command line... I havent test it.. but AP accepts the command...
Use THIS COMMAND...
