1041N APs not joining 2100 WLC
mis
Hopefully this will be an easy solution for some of you.
I have two LAP1041N APs I am trying to setup on a new 2100 WLC (7.0.116.0).  THe APs will blink green fast; then go to a green, red, blue cycle for a min or so; then back to blinking green fast.  Not sure what else to try here.
Thanks for the help.
George Stefanick
Do you have DHCP configured so that the APs will get an IP ?
10 Replies 10
mis
I am currently plugging them directly into the two POE ports on back of the WLC.
George Stefanick
I have both interfaces setup with our DHCP server, that is usually all that is needed when setting up a new WLC, right?
I'm fairly green still.
I went back and checked the settings, the other network guy was trying to get a new subnet going just for wireless.  He did not have all of the routes setup yet.  I reset everything back to our basic network settings and radios came in fine.  Ill get him to look at routes and try it again, thanks for the help!
Excellent! Good deal !
Stephen Rodriguez
on the WLC
show interface summary
show time
debug mac-address < mac of the AP >
debug capwap events enable
debug capwap errors enable
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
is this via command line?
To Steve's point you will need to set the time on the WLC for certificate reasons. But if you console into the AP you will see what its trying to do .. if you can try and capture that and post it would be helpful.
A few things .. The AP needs to be on the same subnet as the WLC management ip address for the broadcast discovery to work. Also time needs to be set on the WLC. These are the basics to get the ap to join
Hello There
PLease do not plug the AP's directly on the back plane of the WLC.
This is not supported as there are ARP issues with the code on the WLC
There are known bugs on this. Please use a switch to configure the AP and WLC connection
Please use a L2/ L3 switch
For a L2 swith the AP and WLC must be on the same VLAN iof the  L2 switch
For AP:
config t
int gig 0/1
swithport access native vlan 1( for ex)
switchport mode access
no shut
For WLC :
config t
int gig 0/2
switchport mode trunk
switchport trunk native vlan 1
no shut
For L3 switch you can assign vlan interfaces :
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080665cdf.shtml#wlc
Also here is the link to the discovery process:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806c9e51.shtml
Tuhin
