1121 Stand alone AP WPA2 config guide
cventici
I am trying to upgrade a stand alone 1121 AP's (bridging, not controlled by a WLC) security config from WEP to WPA2.
I found this guide for the 1310...
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml
But this 1121 menus do not match and I can not find one after a good hour of searching. Does anyone know where I can find a config guide for it?
Thank you!
Leo Laohoo
What IOS version do you have?
Have you tried using the CLI?
12.2(13)JA4
I have cli access as well if needed but would still need a config guide as I am not familiar with these devices.
Thank you.
I recommend you try configuring using CLI.  Unfortunately the business units that are responsible for updating outdated documents have been doing a "bang-up" job.  If you are able to successfully configure WPA2, then I recommend you rate that page appropriately so they (the Cisco business unit) can update the documents.
I see that I can use Migration mode to have both WEP and WPA on the same AP.
I further see that I can use mixed mode so that I have both WPA and WPA2 at the same time.
Does anyone know if I can use both tools to have all 3 encryption types at the same time?
Thanks!
