1130AG
omgjames1
Level 5
Level 5
I have two ssid's on my 1130ag each with different security when I use wep I can get my email on my droid. When i connect to the second ssid and use wpk I can get to the in the Internet but my email will not move in Exchange.
What am I missing?
Nicolas Darchis
if they have different security, the 2 ssids are in different vlans so the problem may be that. It seems you're not too aware about the ap config ? 🙂
isnt one of the ssid for guests ?
I know the entire configuration as I created it. The reason for the two ssid's is that we are moving from wep to wpk. When connected to the new ssid email works fine from pc's, iPad, ect..... Just not my droid.
To answer your other question, no a guest network has not yet been created.
so only Android doesn't work on the new ssid and only emails ?? The rest is working fine on android ?
