1131 AG VLAN using CLI?
mguzman4158
Level 3
Level 3
Hi- I was wondering if there is a way to create vlan(s) using the command line instead of the Web interface. Example: If I used the Web int. I logged in, services, VLAN, New and add the vlan id, name and enable Radio0-802.11G and 11A.
Can I accomplished the same using CLI?
Thank you in advance for your replies.
Cheers!
Can I acomplished the same using CLI?
Cheers!
Rob Huffman
Hi Mauricio,
Have a look at the following (adding VLAN 10);
AP# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
AP(config)# interface Dot11Radio0.10
AP(config-subif)# encapsulation dot1Q 10
AP(config-subif)# interface FastEthernet0.10
AP(config-subif)# end
AP# write memory
From this good doc that has GUI and CLI commands;
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801d0815.shtml#apconfig
Hope this helps!
Rob
Please remember to rate helpful posts.....
Thanks Rob, excellent info and link....
Cheers!
