1131 config issue, not connecting.
alzzstar84
im at a loss, i have setup a 1131 with multiple ssid's, they show up, but neither one will connect. i need 2 ssid's, one open and one protected. this is the config i have so far:
version 12.3
no service pad
service password-encryption
hostname ap
enable secret 5 $1$lrBX$8Z39Oh0JQPGmxWdHEvXo20
ip subnet-zero
ip domain name s02710.US.wal-mart.com
ip name-server 10.223.80.132
no aaa new-model
dot11 ssid Ncc Guest
   vlan 30
   max-associations 50
   mbssid guest-mode
dot11 ssid Ncc Staff
   vlan 20
   max-associations 50
   mbssid guest-mode
dot11 network-map
power inline negotiation prestandard source
username Cisco password 7 14341B180F0B
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 ssid Ncc Guest
 ssid Ncc Staff
 mbssid
 speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
 station-role root
 bridge-group 1
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio0.20
 encapsulation dot1Q 20
 no ip route-cache
 bridge-group 20
 bridge-group 20 subscriber-loop-control
 bridge-group 20 block-unknown-source
 no bridge-group 20 source-learning
 no bridge-group 20 unicast-flooding
 bridge-group 20 spanning-disabled
interface Dot11Radio0.30
 encapsulation dot1Q 30
 no ip route-cache
 bridge-group 30
 bridge-group 30 subscriber-loop-control
 bridge-group 30 block-unknown-source
 no bridge-group 30 source-learning
 no bridge-group 30 unicast-flooding
 bridge-group 30 spanning-disabled
interface Dot11Radio1
 no ip address
 no ip route-cache
 shutdown
 ssid Ncc Guest
 ssid Ncc Staff
 mbssid
 speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
 station-role root
 bridge-group 1
interface Dot11Radio1.20
 no ip route-cache
 bridge-group 20
interface Dot11Radio1.30
 no ip route-cache
 bridge-group 30
interface FastEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
 hold-queue 160 in
interface FastEthernet0.20
 no ip route-cache
 bridge-group 20
interface FastEthernet0.30
 no ip route-cache
 bridge-group 30
interface BVI1
 ip address 192.168.1.175 255.255.255.0
 no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
 login local
end
But, its not working.... what have I done wrong?
2 Accepted Solutions
Stephen Rodriguez
under both of the dot11 ssid, you need to add the following command
authentication open
and you should probably add a PSK to the Staff SSID as well.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
depends on your comfort level.  I prefer the CLI, but GUI works as well.
HTH,
Steve
HTH,
Steve
8 Replies 8
Stephen Rodriguez
authentication open
HTH,
Steve
HTH,
Steve
adding psk, best to do through command or gui?
HTH,
Steve
HTH,
Steve
hmm, get to connect now, but no ip from dhcp.  i figure the ap would just echo, am i incorrect ?
the switchport is a dot1q trunk, that allows VLAN 1, 20 and 30?
HTH,
Steve
HTH,
Steve
thats the issue. these will be running of a simple linksys router. how do i change that? i dont have any catalysts pushing these. just dhcp server on linksys router with 192.168.x.x range.
im very new at these as you can tell, thanks so much for your help stephen!
no worries.
If you don't have a configurable switch, then this won't work.  You will need to remove the VLAN from the SSID, and the interfaces.  The downside is you will either be open, or have a PSK, since we can't use the vlan to differentiate the encryption.
HTH,
Steve
HTH,
Steve
duh... i just realized that... ive been battling this all day today not realizing I cant use vlans... grrr... ok, no big loss, got enough ap's to cover. alright, let me try setting up a basic one and see if I can succeed in that... lol
