Latency Issue for Wireless Users accessing
sachin.sg
We have Wireless Setup and facing the latency issue for Wireless users , Wireless Controller is 2504 and AP are of  3600 Series .
Even we stand below the AP , latency is in range of 19 to 20 ms , while client has Autonomous setup , so when he shifts the connectivity to Autonomous Setup he get latency is range 2 to 8 ms which is good then WLC setup...
While Testing We made the Single AP on which is integrated with WLC and check the Latency , but in these senario also it range from
19 to 20 ms ... ( Also sametime all Autonomous AP's were  Off  )
I am attaching the show techsupport , please anyone can help me to resolve the issue and tell me what fine tunning can be done to resolve the latency issue.
Saravanan Lakshmanan
Try toggling wmm settings on client.
disable powersave on client, if not already.
to eliminate client side issue, try with different model client.
if 2.4 used, disable all lower rates.
fyi, ping traffic on WLC is considered best effort.
