1131 routing problem
marc.lehner
Community Member
Greetings everybody.
Is there a sample configuration that I could use to find my routing problem on my 1131?
It's running in autonomous mode and I can connect my wireless laptop to the network just fine. A 3550 provides DHCP service.
But once I try to access another VLAN or try to go out to the Internet, my setup fails. Been pulling out my hair over this for days. Hope a sample config will help me out. Thanks in advance.
rnigam
Level 2
Level 2
AIR 1131AG is a core layer 2 device which cannot do routing, NATing or layer 3 protocol. Please be specific as to what are you trying to achieve.
rnigam
Level 2
Level 2
By copying me config yo post here and looking at it, I noticed the typo i made in the default gateway! Thanks for the reply!
