1131AG0K9 wireless range
cirino1620
Community Member
When mapping out a floor plan for the 1131AG AP, what is the range of the device. The documentation says 100FT, I assume that is a radius? Any detail would be helpfule.
dennischolmes
Level 11
Level 11
The range of any AP is directly related to the effective radiated isotopic power less the attenuation value of any occlusions between the transmitter and receiver. In other words, how much stuff is between you and the AP. In a perfect clear line of sight world, the range could go as high as 600 feet. The 1131 however has a very limited antenna array. When a 100 foot range is mentioned, that is assuming a normal office environment. The 1242 is slightly better due to the use of external antennae. See the attached document that details the diffrence between the APs.
