1140 AP Broadcast SSID
cnj_bucks
This is our current wireless configuration.  Our stand-alone AP's (1140 and older 1100's) are using Windows RADIUS authentication with WPA2/AES.  We would like to broadcast the SSID for our wireless since currently we are not.
I have enabled the "Set SSID as Guest Mode" and the Multiple BSSID option under Set Beacon Mode.
Once I do that, I scan for new wireless networks and I see my SSID, but when I connect to it, I recieve a notifcation that a certificate was not available to log onto the wireless.  If I look at our RADIUS server, it shows a failure and the user name shows up as <our domain>\guest.  When I am not broadcasting the SSID, the connection is made successfully, and on event viewer I see <our domain>\user name.
Any ideas?
0 Replies 0
