1142_AP output drops
atomike10
Just installed an 1142 a couple weeks ago and since day one, the output drops incriment constantly.  There is only one user connected to this AP, and it is a stand alone.  I saw somewhere that it might be dropping multicast packets, but the command "dot11 igmp snooping helper" is a default command.  I tried taking that out, still nothing.  There are no Ethernet interface drops on the AP or the upstream 3560 switch.  Below is the show interface commands for the connection.  This is a trunk port with multiple networks being sent across, but like I said, there are no issues with ethernet interfaces.
Dot11Radio0 is up, line protocol is up
  Hardware is 802.11G Radio, address is 003a.9927.cc10 (bia 003a.9927.cc10)
  MTU 1500 bytes, BW 54000 Kbit, DLY 1000 usec,
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 02:19:36
  Input queue: 0/1127/0/0 (size/max/drops/flushes); Total output drops: 17063
  Queueing strategy: fifo
  Output queue: 0/256 (size/max)
  5 minute output rate 23000 bits/sec, 18 packets/sec
     7366 packets input, 483840 bytes, 0 no buffer
     Received 435 broadcasts, 0 runts, 0 giants, 0 throttles
     141634 packets output, 21329940 bytes, 0 underruns
     1 output errors, 0 collisions, 0 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
***SUMMARY***
*: interface is up
IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
TRTL: throttle count
  Interface              IHQ   IQD  OHQ   OQD  RXBS RXPS  TXBS TXPS TRTL
* Dot11Radio0              0     0    0 17096     0    0 22000   17    0
* Dot11Radio0.1            -     -    -     -     -    -     -    -   -
* Dot11Radio0.2            -     -    -     -     -    -     -    -   -
* Dot11Radio0.3            -     -    -     -     -    -     -    -   -
* Dot11Radio0.7            -     -    -     -     -    -     -    -   -
* Dot11Radio0.10           -     -    -     -     -    -     -    -   -
Nicolas Darchis
Are you seeing an observable symptom or just worry about that counter ?
If you have interference or something preventing the AP to transmit, the output drops could be explained.
Nicolas
