Problem with WCS Audit status missmatch after upgrade
phino delian
We had problem with wcs Audit status missmatch after upgrade to 7.0.164.3  WLC : 6.0.188.0.
how I can fix the problem?
7 Replies 7
Surendra BG
Please refresh config from controllers on the WCS..
Lemme know if this naswered ur question!!
Surendra
Surendra BG
Hi,  We are still waiting process for refresh configuration for 50 minutes more, it's normal process?
thanks
it should not take 50 minutes..
Surendra
Surendra BG
Hi, What should i do for fix this issue? any suggestion?
Try pinging the WCS from the WLC and vice versa and then try again to refresh config from controllers.. then follow the below if its still not happening..
Please forwrd the trace level logs from the WCS (Specifically WCS0.0.TXT logs) while recreating the issue!!
Surendra
Surendra BG
I can ping the WLC from WCS and Vice versa and then i have try to refresh config from controller, it's same result.
please find attached for trace level log from WCS.
From the logs i am not able to see any errors pointing to the WLC getting audited.. please remove the WLC and then try to re add the same and cature the logs..
Surendra
Surendra BG
