1142N will not connect to 4404 Controller
mano.hernandez
I have a 4404 controller
code:                  4.2.130.0
I am trying to deploy the new Air-LAP1142N-A-K9 and I am getting:
5Fri Jul 23 13:37:44 2010AP Disassociated. Base Radio MAC:c8:4c:75:ae:83:04
6Fri Jul 23 13:37:37 2010AP Associated. Base Radio MAC: c8:4c:75:ae:83:04
7Fri Jul 23 13:37:27 2010AP Disassociated. Base Radio MAC:c8:4c:75:ae:83:04
8Fri Jul 23 13:37:20 2010AP Associated. Base Radio MAC: c8:4c:75:ae:83:04
9Fri Jul 23 13:37:10 2010AP Disassociated. Base Radio MAC:c8:4c:75:ae:83:04
10Fri Jul 23 13:37:04 2010AP Associated. Base Radio MAC: c8:4c:75:ae:83:04
11Fri Jul 23 13:36:54 2010AP Disassociated. Base Radio MAC:c8:4c:75:ae:83:04
12Fri Jul 23 13:36:47 2010AP Associated. Base Radio MAC: c8:4c:75:ae:83:04
13Fri Jul 23 13:36:37 2010AP Disassociated. Base Radio MAC:c8:4c:75:ae:83:04
14Fri Jul 23 13:36:30 2010AP Associated. Base Radio MAC: c8:4c:75:ae:83:04
Currently we have 60 of the 1200 series APs
Any help will be appreciated.
4DigitCCIE
You will need to upgrade your controller code to a version that supports CAPWAP (5.2 or later I believe) to use the 1142.
-John
6 Replies 6
4DigitCCIE
-John
I guess that makes some sense then. I will give that a shot. Is there any flavor of code that is more stable than the other?
Leo Laohoo
1140 is supported on the 6.X and 7.X firmware.  Cisco recommends everyone to stay away from the 6.X code.
hi,
1140 is supported from 5.2 and above.. not mandatorili 6.X or 7.X.
Surendra
Surendra BG
You're right.
you should use 6.0.199.0 or 7.0.98.0 as recommended code for that  platform.
6.0.196 and lower is not recommended.
