1200, ACS 3.1 and EAP Auth Problem
midgar31
I try configure LEAP auth with ACS using local database. I configures just like say in the Cisco Security Suite 2.0 Doc. For some reason Leap auth sometimes work sometimes don't work. Thanks if anyone could help me.
Not applicable
Is this the document you used? can you share the problems you faced??
