1230 LWAPP in a real state...no SSC and continuous reloads
BRYN JONES
Hello
I have a real puzzle here:
We have around 30 1231 LWAPP AP that have been removed from the network when we ran 4.2.61.0.
The flash was cleared of config files and the en_vars file. We are now trying to redeploy them on the netowrk, which is now running 5.2.178.0.
However, we had a failure of one AP upon install and when testing a second on the desk, I see the following on the console:
*Mar 1 00:00:05.351: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1200 Software (C1200-RCVK9W8-M), Version 12.3(11)JX1, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:41 by alnguyen
*Mar 1 00:00:06.285: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to
up
*Mar 1 00:00:07.285: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to down
*Mar 1 00:00:24.361: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:00:24.388: LWAPP_CLIENT_ERROR_DEBUG: lwapp_crypto_init_ssc_keys_and_c
erts no certs in the SSC Private File
*Mar 1 00:00:24.388: lwapp_crypto_init: PKI_StartSession failed
*Mar 1 00:00:24.401: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Re
ason: FAILED CRYPTO INIT.
*Mar 1 00:00:24.401: %LWAPP-5-CHANGED: LWAPP changed state to DOWNXmodem file s
ystem is available.
flashfs[0]: 8 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 4903936
flashfs[0]: Bytes available: 2837504
flashfs[0]: flashfs fsck took 15 seconds.
Reading cookie from flash parameter block...done.
Base ethernet MAC Address: 00:12:80:4f:2b:29
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
link auto-negotiating....
auto-negotiation takes 10000 milli-seconds to complete
ERROR: timeout waiting for auto-negotiation to complete
ERROR: fail to bring ethernet link up
The system has been encountered an error initializing
ethernet port. You may need to check hardware
The system is ignoring the error and continuint boot.
If you interrupt the system boot process, the following
commands will reinitialize ethernet, tftp, and finish
loading the operating system software:
ether_init
tftp_init
boot
Loading "flash:/c1200-rcvk9w8-mx/c1200-rcvk9w8-mx"...###########################
File "flash:/c1200-rcvk9w8-mx/c1200-rcvk9w8-mx" uncompressed and installed, entr
y point: 0x3000
executing...
It appears to me that the SSC is missing and I need to regenerate one but I cannot find any documents telling if it is possible and how to do it.
Is anyone able to comment or provide some light onto how I may be able to rectify this problem?
regards
Bryn
dennischolmes
Level 7
Level 7
I would convert them back to autonomous and then back to CAPWAP with the upgrade tool. This loads a new certificate automatically.
Thanks Dennis...I think you are right. After this post, I started doing further research into how to achieve this and cam across this, which has taken the AP back to IOS. I can now run the conversion tool again. Thsanks.
Do connect the AP directly to your PC not the Router.
The best way to do this is to console into the AP and then make sure the
AP can reach the laptop either through a switch or a crossover cable
directly attaching the laptop and AP.
With your console cable, you will be able to see if you have pressed the
button for 20 seconds.
Using a TFTP Server to Return to a Previous Release
Follow these steps to revert from LWAPP mode to autonomous mode by
loading a Cisco IOS release using a TFTP server:
Step 1 The static IP address of the PC on which your TFTP server
software runs should be between 10.0.0.2 and 10.0.0.30.
Step 2 Make sure that the PC contains the access point image file (such
as c1200-k9w7-tar.122-15.JA.tar for a 1200 series access point) in the
TFTP server folder and that the TFTP server is activated. Monitor the
TFTP program to see the code transfer to the AP.
Step 3 Rename the access point image file in the TFTP server folder to
c1200-k9w7-tar.default for a 1200 series access point,
c1130-k9w7-tar.default for an 1130 series access point, and
c1240-k9w7-tar.default for a 1240 series access point.
Step 4 Connect the PC to the access point using a Category 5 (CAT5)
Ethernet cable. This needs to be a crossover cable if directly connected
to the AP. Or normal ethernet cable if the AP and laptop are connected
to a switch.
Step 5 Disconnect power from the access point.
Step 6 Press and hold MODE while you reconnect power to the access
point.
Step 7 Hold the MODE button until the status LED turns red
(approximately 20 to 30 seconds) and then release.
Step 8 Wait until the access point reboots, as indicated by all LEDs
turning green followed by the Status LED blinking green.
Step 9 After the access point reboots, reconfigure it using the GUI or
the CLI.
If the image doesnt download from your pc's tftp server, you may need to delete the previous tar image on the AP from the console:
Just hold the mode button until the LED is red.
Then, using the console port, make sure the prompt is AP: and do a "show
flash:" on the device and make sure that there is no image that starts
"c1130-rcvk9w8-tar...". If there is an image that starts with that then
delete it with "delete flash:
