1231G LWAPP 12.3(7)JX rebooting over and over
AnthonyRowe
I recently converted a 1231G from 12.3(7)JA IOS to LWAPP 12.3(7)JX. The AP now tries to join the controller (4404)but receives no join response and reboots. I have heard a rumor that there may be a problem with the certificate that's created on the AP during the conversion for certain older 1231's but can't find anything about it on Cisco's site. Does anyone know where I can find documentation on how to fix this? The errors from the AP log follow:
*Mar 1 00:00:23.473: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
AP0011.5c40.6f8d>
AP0011.5c40.6f8d>
AP0011.5c40.6f8d>
AP0011.5c40.6f8d>
AP0011.5c40.6f8d>
Translating "CISCO-LWAPP-CONTROLLER.vassar.edu"...domain server (143.229.1.3)
*Mar 1 00:00:32.247: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned D
HCP address 172.29.100.179, mask 255.255.248.0, hostname AP0011.5c40.6f8d
*Mar 1 00:00:33.249: LWAPP_CLIENT_ERROR: lwapp_name_lookup - Could Not resolve
*Mar 1 00:00:44.200: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Mar 1 00:00:50.201: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: Did not rec
ieve the Join response
*Mar 1 00:00:50.201: LWAPP_CLIENT_ERROR_DEBUG: No more AP manager IP addresses
remain.
*Mar 1 00:00:50.201: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Re
ason: DID NOT GET JOIN RESPONSE.
*Mar 1 00:00:50.201: %LWAPP-5-CHANGED: LWAPP changed state to DOWNXmodem file s
ystem is available.
15 Replies 15
AnthonyRowe
Problem resolved!! I smashed all the 1231's with a sledge hammer! no.... just kidding.
Actually here's what I had to do: make sure the time is set right on all the controllers, AP's and the pc running the upgrade tool, also had to blow away the old config file before uprading. Don't ask me why but if I converted to lwapp without starting from scratch (i.e. no configuration after holding down the mode button and loading a default IOS -12.3(7)JA) it would end up in a reboot loop as before for some reason.
So thank you all very much! I appreciate your help.
Anthony
