08-09-2005 06:04 AM - edited 07-04-2021 11:01 AM
Does anyone know if I can use the AIR-ANTM2050D-R dual band 2.4/5GHz antenna on the 1232AG access point. If the answer is yes, which RP-TNC connectors is it connected to. (2.4 or 5GHz). Also do I need two antennae per AP for diversity.
08-12-2005 01:01 PM
Yes, you can use the AIR-ANTM2050D-R dual band 2.4/5 Ghz antenna on the 1232 AG access point. You can find all the information about the antennas that cisco supports at the following URL.
http://www.cisco.com/en/US/products/hw/wireless/ps469/products_data_sheet09186a008022b11b.html
08-15-2005 12:01 AM
Thanks for your reply.
The reason I posted the question was due to the dual band antennae not being listed on the supported antennae URL you also listed.
I think the dual band may be recent additions from the Airespce product range, hopefully also supported on the 1200 series.
