06-05-2012 07:49 AM - edited 07-03-2021 10:15 PM
All,
I have fat fingered an ACL on my VTY for an Autonomous 1240AG AP. So I am unable to SSH/telnet into the AP. I can however still HTTP into it. Is there a way to remove the VTY ACL from the web interface? or do I have to rest it?
Thanks for your help
Dan
06-05-2012 09:05 AM
If you have console access do it.
If you did not save acl config you can reload the ap.
Otherwise, I am not aware about any other way except resetting the config.
Amjad
06-05-2012 10:08 AM
Hi Amiad
I figured it out. From the web interface if you go to System Software> System Configuration> Show tech-support> command.. you can add cli commands from there.
Dan
06-05-2012 11:49 AM
Thank you.
I almost never used gui so don't know much about it :")
06-05-2012 11:30 AM
If you still have access to the GUI (http) of the unit you can use the command http://AP ipaddress/exec and this will give you the option to go in and click on exce and run cli commands via the GUI.
Example:
xx.xxx.xx.xxx/level/exec
