1242 Antenna Orientation with WCS
mikeyroberts
Hopefully someone here can clarify this for me:
I'm a little confused about what is meant by antenna orientation when using the 1242 with ANT 4941 in wcs.
As it is an omni antenna is the orientation the direction a certain part of the antenna is facing or does it relate to wether you have the antenna set straight or bent on it's hinge.
Or have I missed the point completley??
Mike
Rob Huffman
Hi Mike,
Here is a good thread with an excellent answer from Steve @ Cisco (a wireless guru). The answer he gives should address the question of Omni-Directional antennas in relation to the WCS;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=Security%20and%20Network%20Management&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddbfd2c/1#selected_message
Hope this helps!
Rob
