1252AG-T-K9 antenna gain
Rosa Ladeira
What is the best antenna gain configuration in order to improve low signal ?
Antenna Parameters
Antenna Type       External
Antenna
A
B
C
Antenna Gain   x 0.5 dBi
 Is it possible to configure diversity reception ?
Leo Laohoo
Antenna gains depends on the antenna you've got.  If you have an antenna with a gain of, as an example, 3.0 then the value you enter is 1.5.
Majority of the time, we just leave this value at default.
zero is the value.
Is it the default ?
Some antennas are rated in comparison to dipole antennas. This is denoted by the suffix dBd. Hence, dipole antennas have a gain of 0 dBd (=2.14 dBi).
Note that the majority of documentation refers to dipole antennas as having a gain of 2.2 dBi. Theactual figure is 2.14 dBi, but is often rounded up.
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-antennas-accessories/product_data_sheet09186a008008883b.html
Saurav Lodh
Level 7
Level 7
just for antenna parameters reference
