12-14-2010 09:59 PM - edited 07-03-2021 07:33 PM
Hi All,
In my wireless network i am using 1252G-A-K9 LWAPs and are associated with WiSM modules. They are supposed to show 802.11n networks but showing 802.11g only. Is the anything i need to conifgure additionally in WiSM to get 'n' support ?? Please help.
Rgds,
Shijo.
Solved! Go to Solution.
12-14-2010 10:04 PM
For N speeds..
1>> Either Use OPEN AUTH with NO ENCRUPTION with ALL MCS enabled with WMM enabled.
OR
2>> WPA-2 PSK / Enterprise WITH AES as ENCRYPTION with ALL MCS Enabled and WITH WMM Enabled.
NOTE
WPA-2 TKIP will not yeild N speeds.. only AES enryption is valid..
Make sure on the
WIreless >> 802.11 B/G/N >> High Throughtput >> 802.11N >> Checked.
WIreless >> 802.11 A/N >> High Throughtput >> 802.11N >> Checked.
lemme know how this works out for you!!
Surendra
Please dont forget the rate the usefull posts which answered your question or was helpfull
12-14-2010 10:04 PM
For N speeds..
OR
NOTE
Make sure on the
Surendra
12-14-2010 10:12 PM
did that answer your question
Surendra
12-14-2010 11:46 PM
Hi Surendra,
Thank you very much for your precious support, my issues is resolved.
Thanks again,
Shijo.
