12dBi Mast Mount on 1262 AP
safron007
I want to replace existing 1242s with 1262s. Which are currently in a Heated Nema Enclosures with 12dBi Mast Mount AIR-ANT24120. The 5.0 Ghz Radio is off. So the question is can I use the same Antennas AIR-ANT24120 for the new 1262? I’m assuming yes as long I use connectors A & C are tx/rx; on the center would we leave open or put a rubber duck on it?
Scott Fella
As long as you specify that you are using A & C you will be fine. No need to put a duck on the center antenna port.
-Scott
Thank you.
No problem
-Scott
