1300 Wireless Bridge
pforcier
Community Member
I have been using two 1310 wireless bridges for about six months now. They have been working very well. However this morning they stoped connecting and one says that the Software status is disabled and the hardware status is down.
in the configuration the Radio is enabled and one is set to root the other to non-rooot. Nothing changed just stopped working. I even tried switching witch is root and Non-Root. The problem stays with the Non-Root.
Phillip
Not applicable
PASCAL DECK
Community Member
If you are setting up a bridge as a non-root, the radio interface will not come up unless it is associated to the root, so you be seeing an association problem between the two BR?
