1310 bridge setting
nivanak
Level 3
Level 3
hi!
i configuried 1310 , but it is strangely.
if between root and not-root is 9km,it is failed.
appending my configuring. is it right ?
1. 1310 (root)
interface Dot11Radio0
no ip address
no ip route-cache
ssid tsunami
authentication open
guest-mode
infrastructure-ssid
cca 0
concatenation
distance 20
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
rts threshold 4000
power local cck 100
station-role root
infrastructure-client
bridge-group 1
bridge-group 1 spanning-disabled
2.non-root 1310
no ip address
no ip route-cache
ssid tsunami
authentication open
guest-mode
infrastructure-ssid
cca 0
concatenation
54.0
rts threshold 4000
power local cck 100
station-role non-root
mobile station
bridge-group 1
5 Replies 5
thisisshanky
Level 11
Level 11
What IOS is it ? Try upgrading to 12.3.2 JA and see if it resolves the problem.
If a lower version than 12.3.2.JA, Try changing Cca parameter to 60 and see if it helps!
command is "cca 60"\
http://www.cisco.com/en/US/products/hw/wireless/ps5279/prod_release_note09186a00802146c0.html
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
nivanak
Level 3
Level 3
and 1310 bridge's LED COLOR is strange.
now, only R , S , E LED are blinking(green).
Install LED is not blinking.(no color).
of course, 2 bridges are same actual condition.
help me.
Thats normal. R, S, E LEDs blink at different rates depending on the signal strength. Check this chart for blink rates and signal strengths.
http://www.cisco.com/en/US/products/ps5861/products_installation_guide_chapter09186a008021e5ee.html#wp1042233
Sankar Nair
thank to your answer.
but i have a question.
now install mode is off. 2 bridges are off.
another R,S,E LED is no problem.
after setting bridge with two 1310 , istall LED is off now.it is strangely.
by your link site,off signal(install LED) is startup.
if install LED of root bridge is green , is it right ?
i do not understand.
sorvarit
Level 4
Level 4
Try to set the mac address (radio interface) to the root parent under in the webinterface on the non root bridge (Network interfaces> Radio0-802.11g> Settings). Solved our problems with the BR1310. Couldnt find eachother 5m away before doing this... They are 4km away so it could be something with distance in your case also. What type of antennas do you use? We use 24dbi grid antennas with 10m and 20m heliax cables.
Orjan
