1310 mesh network?
hello experts!!!
is it possible to do a single-band mesh with the 1310 ap?
which controller code will support this?
any walkthrough ideas?
thanks!
is the 1500 ap the only ap that can be meshed?
checked the 1242 and 1300 and the mesh role option is not in the ap page.
Correct, the 1500 series is the only access point that can do Mesh. 1310G and 1410A bridges only have one radio each, so mesh isn't an option.
1240s do have an option for using the A radio as a backhaul to another access point while using the G radio to connect clients, but this isn't the same as Mesh.
