cisco-lwapp-controller where to point?
marcuslejon
the dns entry cisco-lwapp-controller should that be pointed to the management interface or the ap-manager interface?
And if i have two WLC's for failover. should both be entered as a dns record under cisco-lwapp-controller?
grzegorz.ciolek
Management IP.
If both are in the same mobility group only one entry is required in DNS.
Cheers
Greg
sanamon
I would put both in there for failover.
However this DNS record is only used for APs that doesn't have a primary controller configured (normally the first time its powered on)
