1310 -r signal
albertldee
i purchase a 1310 aironet that i would like to use as a AP to connect to from my laptop 1km away i'm planning on putting it on my roof which is about 12ft however i can add a 10ft pole making it 22ft what antenna can i use with it that would give me the best signal i do not have line of sight to the remote location any suggesion
srosenthal
Level 4
Level 4
There are a few issues with this idea. One, you need clear line of site. Two, your laptops wireless card will not have the transmit power to reach the bridge.
If you were going to use two 1310 bridges, then I would suggest using the internal antenna model as that will work fine. If you prefer to use the external antenna model, then I would suggest a yagi antenna.
Seth
