1400 antenna azimuth plot
jwarner
The AIR-BR1410A-A-K9 has a built in 22.5 dB antenna. While I can find azimuth plots for all the external antennas sold as separate products for the bridge with an N connector, I can't find anything for the built-in patch array on the integrated model. I expect to be asked by the forces for voluntary frequency coordination what lobes hang off the antenna center line. Does anyone know where I can find the azimuth plot for the built-in antenna?
The first data sheet has a polar plot of antenna sensitivity for every antenna EXCEPT the 22.5 dB built-in. I've been asked whether there are side lobes to the radiation pattern. I don't know how to answer that without a polar plot.
The data sheet for the radios contains no polar or azimuthal radiation information at all.
I had the same question and had to open a tac case to get the information. I am attaching the the information that you need.
hope this helps
scott
