07-07-2005 07:57 AM - edited 07-04-2021 10:57 AM
When I view web page of 1410 radio is show ethernet enabled and up but radio as disabled and down. I have tried to enable but to no avail. Is this a sign my radio has gone bad?
07-08-2005 03:36 AM
If you have changed the config check:
1. That the interface has a ssid
2. That the encryption keys are setup correctly (is this the non-root bridge?)
3. If you are using vlans make sure they are setup correctly. (ie keys assigned to appropriate native vlan)
07-08-2005 05:15 AM
I have not modified any config or settings. We did have some rather nasty thunderstorms come through before this happened. I'm trying to determine is this may have had something to do with it, hence my question. If I did had a bad radio what would I see?
03-06-2012 09:56 AM
- How do you check the encryption is setup correctly?
- Is the encryption on the non-root to match with the
encryption vlan 120 key 1 size 128bit 7 *******keys******** transmit-key
on the root or the encryption without vlan?
