150 AX Mesh not Shown as Mesh but as Infra to Clients
Hello, I have configured 2 150 AX access points to work as a mesh network, but when I scan the networks with my linux laptop I see them listed as "type: Infra" and when testing the automatic switch from one node to another does not work.
Any advise ?
helpcenterus
Hallo @aleksandarkirilov
The "type: Infra" designation suggests that the mesh functionality might not be kicking in as expected. First, ensure that both access points are set up with the correct mesh configurations. Check if there are any firmware updates for the access points that might address this behavior. Additionally, verify that the mesh feature is enabled and properly configured on both devices. When testing the automatic switch, consider checking the signal strength between the nodes to ensure they are within range for seamless transitioning. It might also be helpful to review your Linux laptop's compatibility with the mesh network.
