1510 Mesh AP Debug
CFayNTAdmin83
Level 3
Level 3
                   Hello friends!  I am kicking myself because I cann't find the route of my problem so hopefully somebody can!  I have two Cisco 1510 Mesh Access points one is the root.  I am working with a Motorola VC70 Windows CE 7.0 unit.  The problem that I am having is that everytime the unit roams from the root to the mesh it drops connection.  I was doing a debug on the mesh AP and it was saying that "drop frame, sta sent the frame on wrong vapid" when the unit was trying to roam.  Does anybody knows what this means?  I am working with one SSID (WPA2-PSK) and I have the client on the 2.4ghz channel, channel 11 for the root and 1 for the mesh, and the 5ghz is working as the backhaul on bith channel 161.   Any ideas to point me in the correct direction would help!!!
Jason
Scott Fella
You should do a debug on the client. Now does a windows client roam fine or any other client roam fine? Did you isolate this to that certain device? What is the coverage like when you are in the area where the devices roam?
-Scott
When I do a debug on the client and when the unit roams from the working AP to the Mesh the debug stops ( I am doing this from a 2106 Controller).  But when the Client roams back to the working AP it shows this.  Which I assume is a successful roam.  Any other client does the same, Laptop with Intel card, Motorola MC9090 Handheld.  It looks like it fully disassociates and looks for its IP?  The coverage is very good between the root and the Mesh AP.  RSSI is at -42 and both interfaces pass the noise interferance profile.  For the coverage that is needed we are using omni antennas and a site survey for the area is around -52 to -66.
(Cisco Controller) >Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 Reassociation re
ceived from mobile on AP 00:0b:85:89:f0:50
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 STA - rates (4): 130 132 139 150 12
18 24 36 48 72 96 108 0 0 0 0
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 STA - rates (12): 130 132 139 150 12
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 Processing RSN IE type 48, length 20
for mobile 40:83:de:16:f3:81
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 10.2.42.107 RUN (20) Deleted mobile
LWAPP rule on AP [00:0b:85:8f:ad:c0]
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 Updated location for station old AP
00:00:00:00:00:00-0, new AP 00:0b:85:89:f0:50-1
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 10.2.42.107 RUN (20) Change state to
START (0) last state RUN (20)
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 10.2.42.107 START (0) Initializing p
olicy
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 10.2.42.107 START (0) Change state t
o AUTHCHECK (2) last state RUN (20)
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 10.2.42.107 AUTHCHECK (2) Change sta
te to 8021X_REQD (3) last state RUN (20)
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 10.2.42.107 8021X_REQD (3) Plumbed m
obile LWAPP rule on AP 00:0b:85:89:f0:50
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 apfPemAddUser2 (apf_policy.c:212) Ch
anging state for mobile 40:83:de:16:f3:81 on AP 00:0b:85:89:f0:50 from Associate
d to Associated
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 Stopping deletion of Mobile Station:
(callerId: 48)
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 Sending Assoc Response to station on
BSSID 00:0b:85:89:f0:50 (status 0)
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 apfProcessAssocReq (apf_80211.c:3888
) Changing state for mobile 40:83:de:16:f3:81 on AP 00:0b:85:89:f0:50 from Assoc
iated to Associated
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 Creating a PKC PMKID Cache entry for
station 40:83:de:16:f3:81 (RSN 2)
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 Adding BSSID 00:0b:85:89:f0:5f to PM
KID cache for station 40:83:de:16:f3:81
Mon Sep  9 12:15:33 2013: New PMKID: (16)
Mon Sep  9 12:15:33 2013:      [0000] 53 e6 21 d4 9b a1 a9 cc 5c ed 86 a9 71 00
59 b7
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 Initiating RSN PSK to mobile 40:83:d
e:16:f3:81
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 dot1x - moving mobile 40:83:de:16:f3
:81 into Force Auth state
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 Skipping EAP-Success to mobile 40:83
:de:16:f3:81
Mon Sep  9 12:15:33 2013: Including PMKID in M1  (16)
59 b7
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 Sending EAPOL-Key Message to mobile
40:83:de:16:f3:81
                    state INITPMK (message 1), replay counter 00.00.00.00.00.00.
00.00
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 10.2.42.107 Removed NPU entry.
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 Received EAPOL-Key from mobile 40:83
:de:16:f3:81
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 Ignoring invalid EAPOL version (1) i
n EAPOL-key message from mobile 40:83:de:16:f3:81
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 Received EAPOL-key in PKT_START stat
e (message 2) from mobile 40:83:de:16:f3:81
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 Stopping retransmission timer for mo
40:83:de:16:f3:81
                    state PTKINITNEGOTIATING (message 3), replay counter 00.00.0
0.00.00.00.00.01
:de:16:f3:81
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 Received EAPOL-key in PTKINITNEGOTIA
TING state (message 4) from mobile 40:83:de:16:f3:81
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 10.2.42.107 8021X_REQD (3) Change st
ate to L2AUTHCOMPLETE (4) last state RUN (20)
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 10.2.42.107 L2AUTHCOMPLETE (4) Plumb
ed mobile LWAPP rule on AP 00:0b:85:89:f0:50
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 10.2.42.107 L2AUTHCOMPLETE (4) Chang
e state to RUN (20) last state RUN (20)
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 10.2.42.107 RUN (20) Reached PLUMBFA
STPATH: from line 4373
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 10.2.42.107 RUN (20) Adding Fast Pat
h rule
  type = Airespace AP Client
  on AP 00:0b:85:89:f0:50, slot 1, interface = 1, QOS = 0
  ACL Id = 255, Jumbo Frames = NO, 802.1P = 0, DSCP = 0, TokenID = 1506
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 10.2.42.107 RUN (20) Successfully pl
umbed mobile rule (ACL ID 255)
Mon Sep  9 12:15:33 2013: 40:83:de:16:f3:81 10.2.42.107 Added NPU entry of type
