Configuration Cisco AP 2600(AIR-CAP2602I-E-K9) and Cisco wireless controller 2500 ?
waleed3sa
This is the first time that I work with this type of devices(Cisco Ap 2600(AIR-CAP2602I-E-K9) and wlc 2500).... my experience in CCNP (router and Switch)
How to  configuration Cisco Ap 2600(AIR-CAP2602I-E-K9) and wlc 2500 ?
Please Find the attach (map of  Cisco  Device)
6 Accepted Solutions
Sahil Mengi
Here are the docs for you to configure the basic switch port config for AP's i.e 2600s and wlc.
Wlc port should be configured as trunk.
AP port has to be access.
CAP2600 series requires a wlc software of minimum 7.2.110.0 (Make sure you have this or above release)
To upgrade if you need to follow this.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805f381f.shtml
1. http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080665cdf.shtml (SW port configs)
2. http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806c9e51.shtml
(ANother very importand thing, discovery mechanism, choose appropriately)
If you choose dhcp option 43, it uses TLV format. Type is always f1, length is 4*(no.of wlc for which you want to provide discovery for , in ur case one) Value = Hex conversion of the management ip address of wlc.
A video for the process,
http://www.youtube.com/watch?v=oOh_Iv1CHxQ.
Sahil
You need zero config on the access point itself, once switchport and discovery is configured correctly, there is ip reachability, it should be able to discover and join the wlc.
Sahil
Connect the ap to a switchport that is setup as an access port and for now on the same vlan as the WLC management. Once the ap boots up and gets an IP address, it will discover the WLC since its in the same layer 2 subnet. There is no config t as this is a lightweight access point. The ap configuration will be done once the ap joins the WLC and is in the REG state
-Scott
Please follow the instructuions on this forum by Surendra
https://supportforums.cisco.com/thread/2043235
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
You can either have the AP get a dhcp address which is prefered, then the AP will join the WLC and then from the WLC you change the AP's ip address or you can do ti this way:
https://supportforums.cisco.com/docs/DOC-18274
Scott
-Scott
Here is a guide you should read also.  This talks about how an AP registers to a WLC:
Scott
-Scott
9 Replies 9
Sahil Mengi
Sahil
Sahil
waleed3sa
thank you Sahil Mengi for quick help
how set ip in  ِِAP 2600?
There are no  ..... config t
AP7cad.74db.510e#
AP7cad.74db.510e#
AP7cad.74db.510e#
AP7cad.74db.510e#
AP7cad.74db.510e#
AP7cad.74db.510e#
*Mar  1 00:13:16.327: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:13:26.327: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:13:36.327: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:13:46.327: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:13:56.327: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:13:56.327: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP
. Renewing DHCP IP.
*Mar  1 00:14:06.327: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:14:16.327: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:14:26.327: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:14:36.327: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
AP7cad.74db.510e#
AP7cad.74db.510e#
AP7cad.74db.510e#
-Scott
waleed3sa
p:
ap:
ap:
ap:
ap:
ap:
ap: set ip_addr 192.168.104.12
ap:
ap: set netmask  255.255.255.0
ap:
Scott
-Scott
waleed3sa
thank you Scott Fella
please check my config below
Wlc 2500 configure
Welcome to the Cisco Wizard Configuration Tool
Enter Administrative User Name (24 characters max): Cisco
Enter Administrative Password (24 characters max): Cisco1
Service Interface IP Address Configuration [none][DHCP]: none
Enable Link Aggregation (LAG) [yes][NO]: No
Management Interface IP Address: 192.168.104.20
Management Interface Netmask: 255.255.255.0
Management Interface Default Router: 192.168.104.1
Management Interface VLAN Identifier (0 = untagged):138
Management Interface Port Num [1 to 4]: 1
Management Interface DHCP Server IP Address: 192.168.104.2
AP Manager Interface IP Address: 192.168.104.3
multicast IP Address: 239.0.0.0
AP-Manager is on Management subnet, using same values
Virtual Gateway IP Address: 1.1.1.1
Mobility/RF Group Name: www
Network Name (SSID): test
Allow Static IP Addresses [YES][no]: yes
Configure a RADIUS Server now? [YES][no]: no
Enter Country Code (enter 'help' for a list of countries) [US]: SA
Enable 802.11b Network [YES][no]: yes
Enable 802.11a Network [YES][no]: yes
Enable 802.11g Network [YES][no]: yes
Enable Auto-RF [YES][no]: yes
Enter the NTP server IP address:
Configure the Switch for the WLC
interface GigabitEthernet1/0/1
description Trunk Port to Cisco WLC
switchport trunk allowed vlan all
switchport mode trunk
no shutdown
Configure the Switch for the APs
interface GigabitEthernet 0/17
switchport access vlan 138
switchport mode access
no shutdown
____________________________________________________________________
my problem in ap
after connect console cable to ap
AP7cad.74 db.510e#
AP7cad.74 db.510e#
how  to put ip in ap ?
Scott
-Scott
Scott
-Scott
