1532i not joining WLC CT81K9
We have around 20 APs Model AIR-CAP1532I-E-K9 recently purchased and trying to deploy them in our network with WLC CT8510-K9. AP is getting IP but couldn't join WLC then it keeps rebooting. I have accessed AP by console and got the below
boot_method is set to IOS_BOOT, boot IOS bootloader in NOR flash
Loading .text @ 0x84000000 (208000 bytes)
Loading .rodata @ 0x84032c80 (39072 bytes)
Loading .data @ 0x8403c520 (3264 bytes)
Loading .data.rel.local @ 0x8403d1e0 (1084 bytes)
Loading .data.rel @ 0x8403d61c (124 bytes)
Loading .data.rel.ro @ 0x8403d698 (960 bytes)
Clearing .bss @ 0x8403da60 (161116 bytes)
Clearing .scommon @ 0x84064fbc (56 bytes)
## Starting application at 0x84000000 ...
IOS Secondary Bootloader - Starting system.HW Test Status(0)
Ath Nand ID: 95:80:f1:2c:00
Using driver version 1 for media type 2
Valid buffers 430
total430 430
success found all blocks
start end 65 82
found in range
high low end 2652 2089 82
Invalid version Number for sector = 1052719 read = 34989 expect =2221Xmodem file system is available.
mifs[0]: 213 files, 11 directories
mifs[0]: Total bytes : 131334144
mifs[0]: Bytes used : 27451392
mifs[0]: Bytes available : 103882752
mifs[0]: mifs fsck took 1 seconds.
Base Ethernet MAC address: 00:81:c4:88:61:20
Setup MAC....
Waiting for PHY auto negotiation to complete...Port 0 Negogiation success.
Ethernet speed is 1000 Mb - FULL duplex
Scorpion ----> F1 PHY *
: cfg1 0xf cfg2 0x7215
Loading "flash:/ap1g3-k9w8-mx.153-3.JC/ap1g3-k9w8-mx.153-3.JC"...##########################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
bad mzip file, uncompressed to wrong length , (0x2424da4 != 0x24253e0)
Error loading "flash:/ap1g3-k9w8-mx.153-3.JC/ap1g3-k9w8-mx.153-3.JC"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
ap1g3 Boot Loader (ap1g3-BOOT-M) Version 15.2(4)JB3b, RELEASE SOFTWARE (fc1)
Compiled Thu 23-Jan-14 21:52 by prod_rel_team
ap:
7 Replies 7
marce1000
 - Note that the CT8510-K9 is long end of life and beyond support , if these APs you bought have an incompatible software version on them , then it simply may not work. And probably it then can't be fixed neither.
   As  you purchased AP's recently you should look for a modern controller based on the 9800 platform series
   The virtual version can be downloaded and deployed for free , but the APs must be licensed.
 M.
But There are 5 APs Model 1526 connected and working
               >....But There are 5 APs Model 1526 connected and working
   - Then compare the software version on both working and not working with show version on the APs (e.g.)
 M.
marce1000
  - Added , possibly the only chance you may have for the 8510 is going to the last release
                 https://software.cisco.com/download/home/284493532/type/280926587/release/8.5.182.0
   and check if that can help ,
 M.
What about the error below
The system is unable to boot automatically. The BOOT environment variable needs to be set to a bootable image.
      >What about the error below
                    (from your initial post)
   The installed software looks corrupt or invalid on these APs, you may need to install the needed software
    again in them,
 M.
That means the AP flash is corrupted and the AP software is corrupted.  This was a common problem on old software and that software is very old!  You will need to format the flash and re-install the software as per https://community.cisco.com/t5/wireless-mobility-knowledge-base/access-point-rommon-recovery-ap-prompt-recovery-example/ta-p/3119495
The flash issues are documented at:
https://www.cisco.com/c/en/us/support/docs/field-notices/703/fn70330.html
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/213317-understanding-various-ap-ios-flash-corru.html
The last downloadable software version for the AP which will work with 8510 is:
https://software.cisco.com/download/home/284620606/type/280775090/release/15.3.3-JF15
The latest software available for 8510 is 8.5.182.12 - link below.  You will normally need a Cisco service contract to download that but because 8510 is already end of support (as Marce pointed out) you will not be able to purchase a new support contract.  Whoever you purchased the 8510 from might be able to help you.
Take note of the field notices below which may impact you.
