1542i Converting a CAWAP AP into a Mobility Express AP
r_m
Hello everyone
I followed the conversion procedure that I write below,
AP#ap-type mobility-express tftp://<TFTP Server IP>/<path to tar file>
with firmware : AIR-AP1540-K9-ME-8-7-102-0.tar
but the answer is as follows
Image transfer complete.
Image downloaded, writing to flash...
do CHECK_ME, part2 is active part
upgrade.sh: Error: image not found.
+ do_upgrade CHECK_ME
+ [ ! -r /tmp/part.tar ]
+ loudlog Error: image not found.
+ logger -p 0 -t upgrade Error: image not found.
+ echo upgrade.sh: Error: image not found.
+ return 1
+ status=1
+ set +x
Error: Image update failed.
Has anyone had similar problems?
r_m
Goodmorning everyone,
    the solution is to perform the conversion outside the class where the Controller Mobility Express is present and use the following command
ap-type mobility-express tftp: // <ip tftp server> / <path file .tar>
*** the error was just to perform the ap conversion in the same CME class.
once the following code is displayed
Image signing verify success.
AIR-AP1542I-E-K9
This is AP1542, use btldr_crete.bin.lzma/btldr_crete_md5 for uboot
Verify returns 0
Unlocking /dev/mtd4 ...
23+0 records in
23+0 records out
upgrade.sh: part to upgrade is part1
upgrade.sh: activate part1, set BOOT to part1
upgrade.sh: AP primary version: 8.7.102.0
Archive done.
restart the AP and move it to the class where the CME is present.
5 Replies 5
Rasika Nayanajith
I would try with other version 8.5.120.0 & see you face same issue ?
Rasika
Leo Laohoo
Alternatively, try this:  archive download-sw  tftp://<TFTP Server IP>/<path to tar file>
r_m
AIR-AP1542I-E-K9
Verify returns 0
23+0 records in
23+0 records out
Archive done.
Hi, when do you say the class do you referring to the network segment?
He definitely, does.
