1700 broadcast problem
erik bakke
Frequent Visitor
Frequent Visitor
Hi!
I have vWLC running on vmware.
2AP 1702i joined, but ​APs is not broadcasting at all
​interfaces is up, no error etc.. tested 8.0.120.0 and 8.1.121.0 release.
Broadcast ssid is on, wlan is enabled and ap and wlan in correct ap group. also tested default group
Controller and ap is connected to cisco 3560x in the same vlan
AP logs:
*Sep 25 10:58:53.263: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.25.2
*Sep 25 10:58:53.635: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Sep 25 10:58:53.643: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Sep 25 10:58:53.731: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller SHAWLC
*Sep 25 10:58:53.807: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Sep 25 10:58:54.515: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Sep 25 10:58:54.635: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Sep 25 10:58:54.671: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Sep 25 10:58:54.679: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Sep 25 10:58:54.807: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Sep 25 10:58:55.663: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Sep 25 10:58:55.707: %DOT11-6-DFS_SCAN_START: DFS: Scanning frequency 5320 MHz for 60 seconds.
*Sep 25 10:58:55.711: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Sep 25 10:58:55.719: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Sep 25 10:58:55.727: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Sep 25 10:58:56.711: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Sep 25 10:58:56.719: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Sep 25 10:58:56.747: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Sep 25 10:58:57.747: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Sep 25 10:59:16.391: %CLEANAIR-6-STATE: Slot 0 disabled
*Sep 25 10:59:16.391: %CLEANAIR-6-STATE: Slot 1 disabled
*Sep 25 10:59:56.751: %DOT11-6-DFS_SCAN_COMPLETE: DFS scan complete on frequency 5320 MHz
Broadcast SSID
 Enabled
802.11a Network State
802.11b/g Network State
802.11a/n/ac Radios Detail
802.11b/g/n Radios Detail
Dual-Band Radios Detail
All APs
 Detail
0 Replies 0
