09-23-2015 03:25 AM - edited 07-05-2021 03:59 AM
Dear all,
We plan to install on the same site these devices :
- AIR-CT2504-50-K9 – as primary controller
- AIR-CT2504-HA-K9 – as backup controller
- Software version 7.6.130
I didn't find documentation on how to make the HA between the devices.
The two devices will be on the same site and they will be NOT in the N+1 configuration.
As there is no redundancy port on the 2504, is it need a physical link between the two devices ?
Thank you in advance,
Best regards,
Vince.
Solved! Go to Solution.
09-25-2015 01:15 AM
Hi Vince,
It same configuration as N+1. There is not much difference except one command.
There is no need to connect both WLC physically (even there is no option to connect.)
Use my post for Conifg guide:
https://rscciew.wordpress.com/2014/06/07/n1-high-availability-configuration-on-cisco-2504wlc/
*** Don't use this command on secondary WLC( If you dont want to do N+1)
(WLC2) >config redundancy unit secondary
Don't forget to rate helpful posts
09-25-2015 04:38 AM
09-25-2015 01:15 AM
Hi Vince,
09-25-2015 06:30 AM
Hi Sandeep,
Thank you very much for your help.
In fact I had already saw your post on your website and followed your recommendations
Thank you again.
Vince.
09-25-2015 04:38 AM
