1702i Access Points and LED colors
Kevin Parsons
Hi all!
Historically, Cisco has used the same LED color schemes to indicate status of the AP, i.e. solid green = ready to go, solid blue = at least one connected client, et. al.
Lately, I have deployed 1702i's on a 2504 WLC running firmware version 8.0.115.0.  When clients connect to the AP's, the LED's stay solid green.  I re-created this scenario by connecting a 1702i to my 5508 WLC running firmware version 8.0.115.0, and got the same results.
Is the 1702i running on different LED codes?  Or is this a fluke based upon the WLC or AP firmware version?
Incidentally, the same 1702i that I connected to my 5508, I also connected to my 3850 switch running IOS-XE 03.06.00E, glows amber with a connected client.
Thanks in advance for any ideas/suggestions/information.
Kevin
mohanak
LED Status Indications
Message
Type
Status
LED
Message
Meaning
Boot loader status sequence
Blinking green
DRAM memory test in progress
DRAM memory test OK
Board initialization in progress
Initializing FLASH file system
FLASH memory test OK
Initializing Ethernet
Ethernet OK
Starting Cisco IOS
Initialization successful
Association status
Chirping Green
Normal operating condition, but no wireless client associated
Green
Normal operating condition, at least one wireless client association
Operating status
Blinking amber
Software upgrade in progress
Cycling through green, red, and amber
Discovery/join process in progress
Rapidly cycling through red, green, and amber
Access point location command invoked
Blinking red
Ethernet link not operational
Boot loader warnings
Blinking amber
Configuration recovery in progress (MODE button pushed for 2 to 3 seconds)
Red
Ethernet failure or image recovery (MODE button pushed for 20 to 30 seconds)
Blinking green
Image recovery in progress (MODE button released)
Boot loader errors
Red
DRAM memory test failure
Blinking red and amber
FLASH file system failure
Blinking red and off
Environment variable failure
Bad MAC address
Ethernet failure during image recovery
Boot environment failure
No Cisco image file
Boot failure
Cisco IOS errors
Red
Software failure; try disconnecting and reconnecting unit power
Cycling through red, green, amber, and off
General warning; insufficient inline power
8 Replies 8
Leo Laohoo
The design of the 1600 and 1700 calls for a single-coloured LED only.
Thanks, Mohanak,
I guess I never even considered the "Getting Started" guide.  doh!
I am curious why Cisco decided to change things up; historically "blue" indicates connectivity.
One word:  COST.
To keep the cost of the AP 1K, aka 1600 and 1700, the design for the LED was intentionally specified as a single-colour only.
Hi. Sometimes I've got the AP with the BLUE led indicator, and sometimes green.
Well, when I got green led status I've one or more client connected.
whe I got blue led status, I've lots of client connected, and usually the AP is loaded with 30 clients or more..
although I coundn't find are these values in the datasheets!
Hi, i want to ask something, i have Cisco Aircap 1702i-F-K9, i want to start configuration but i cant login into console terminal with serial console cable, that terminal console just open but there is nothing login user and etc, how can i configuration if i cant login into console terminal ??? and why i cant login into terminal console ?? thank you
mohanak
Message
Type
Status
LED
Message
Meaning
Blinking green
DRAM memory test OK
Ethernet OK
Starting Cisco IOS
Association status
Chirping Green
Green
Operating status
Blinking amber
Blinking red
Blinking amber
Red
Blinking green
Boot loader errors
Red
Bad MAC address
No Cisco image file
Boot failure
Cisco IOS errors
Red
I have faced a problem to get access to Cisco Aironet provision mode (CLI Config), my troubleshooting steps  are listed below :
1- I have connected a the AP to Cisco switch via Ethernet cable to power it over PoE.
2-I have made a RESET form mode button then blinking has been changed from Green to Amber as usual.
3-When I make the connecting the connection between the PC serial port & AP Console port via USB-RJ45 console cable I'm getting the access to provision cmd window but when I press Enter or any Key there is no response or some times it shows some random letters, numbers & symbols.
4-I have used the same way to get the access to the Switch, then it has been done successfully.
5-I have tried the same scenario for four different APs, no thing has been changed (same problem).
For your advice please.
Best Regards,
Mohammed Al-Numany
