1815i
arun1290
Community Member
Iam using 1815I AP with mobility Express 8.10.151.0.
clients gets refreshed every 10-20 minutes .Most of the clients get reconnects automatically within few seconds.But few get diconnected.
Earlier i used mobility express 8.5.151.0.In no client refreshing thing.There is no issue while using that version.
Is there a soution to stop client refreshing ?
Pls help.
Mark Elsen
 - You can have a checkup  of the mobility express controller configuration with : https://cway.cisco.com/tools/WirelessAnalyzer/
, clients may have outdated drivers (make sure they are up to date) . You can also do client debugging on the controller , these can be analyzed with : https://cway.cisco.com/tools/WirelessDebugAnalyzer/
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rich R
Suggest update to 8.10.183.0 https://software.cisco.com/download/home/286306794/type/286289839/release/8.10.183.0.
TAC recommended https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#anc12 still saying 8.10.181.0 but they just haven't updated it yet although 8.10.181.0 and 8.10.182.0 have been deferred.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
