1832i cli hangs after bootup
M-Square
Level 3
Level 3
I have an odd problem, wondering if someone has seen it
I have an 1832i that was in capwap mode.  I was converting to ME and after that things went down hill.
The 1832i sli was working hence I was able to login and point it to the tftp server to download the ME .tar file.  Everything looked normal.  After it boots though the cli hands at the below prompt.  The console simply will not accept inputs from the console.  I even tired to copy and past, nothing.  Scrolling through the boot syntax I can see reference to 9600/8n1 so I think the serial interface setup with the correct baud etc.
Any thoughts?
Cheers
Hostname is not compliant to RFC !.
Hostname can contain max of 24 characters namely Upper/lowercase letters,numbers,dot,hyphen.
Hostname should always start with an alphabet and should not end with '.' or '-'.
PnP config is saved to storage
Configuring management interface
Enabling mgmt via wireless
Enabling Provisioning SSID
SSID: CiscoAirProvision, Admin Status: 1, Interface Name: management, 802.11 Auth: WPA2-PSK, Wi-Fi Protected Access : Enabled
(Cisco Controller)
Cisco Aironet 1830 Series Mobility Express
Welcome to the Cisco Wizard Configuration Tool
Use the '-' character to backup
Enter Administrative User Name (24 characters max):
Leo Laohoo
Try a different computer.  Maybe the application used for the console needs to be rebooted?
M-Square
Level 3
Level 3
Seem to have located the issue, serial port on PC needed a kick.
Also - from my experience certain USB-serial cables just don't work with certain APs so switching to a different brand of cable can sometimes help.  Otherwise the usual culprits - change/update the cable driver, reboot the PC, delete and re-discover the cable from device manager.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
