SSID speed?
Andrey.A
Frequent Visitor
Frequent Visitor
Hi all,
Let say i have 3 WLANs, with 3 different SSIDs. CORP-ssid for employees laptops, CORP-mobile for employees phones and guest-ssid for guest. If I have 10Mbps internet link, is it possible to set some limitations on those WLANs, so that CORP-ssid use 60% of the link, and other two SSID 2 x 20% ?
I want to set higher "privileges" for CORP-ssid in terms of bandwidth and usage.
Andrey
balaji.bandi
You can do based on the VLAN Associated with SSID
BB
Leo Laohoo
Depending on the model of WLC and the firmware loaded each SSID can be configured the inbound and outbound bandwidth - per Mbps only.
Andrey.A
Frequent Visitor
Frequent Visitor
Thank you both for the reply. @Leo Laohoo it is 2504 WLC with 8.5.140.0 image, can you point me to some configuration guide?
2504 does not support bandwidth limiting per SSID.
Feature only supported on 5508, WiSM2 and bigger appliances.
