Showing results forĀ
Search instead forĀ
Did you mean:Ā
[2.4G_HT40] - How to enable 2.4G HT40 on Cisco 2702?
comic.chang1
Does any images can enable 2.4G HT40 on Cisco 2702?
I would like to use 2.4G HT40 to test wifi throughput,
Thanks a lot.
Do Not enable this, in 2.4GHz, you have 3 channel to work with, if you bond 2 channels together then there won't be enough channel for other AP nearby and end up with interfering each other.
Rasika
*** Pls rate all useful responses ***
Hi Rasika:
Thank you very much for replying,
I would like to test our DUT's 2.4G HT40 throughput by conductive mode with Cisco2702AP,
If possible, Do you have any methods or suggestions to enable 2.4G HT40 on Cisco2702AP? Or Engineering build
