2602 no console output
Goga
Frequent Visitor
Frequent Visitor
Hello everyone! I have connected console cable to my new AIR-CAP2602I, but there is no output from AP. It is connected to 2960-S PoE switch and getting IP address from DHCP server, but i cannot connect to it by telnet or ssh. Only icmp responds. I also installed vWLC 8.0 and there are messages in log:
 *spamApTask5: Feb 18 14:48:05.339: #LOG-3-Q_IND: spam_lrad.c:1689 Ignoring discovery request received on a wrong VLAN (48) on interface (1) in L3 LWAPP mode from AP
and
*spamApTask5: Feb 18 14:48:05.339: #CAPWAP-3-DISC_MAX_DOWNLOAD: capwap_ac_sm.c:1939 Ignoring discovery request from AP
Is there any way to get access to this type of AP?
That isn't a good check:)  Many others on the forum ran into the same issue and tried connecting to a switch or router to verify. This doesn't work... Test with connecting to another AP.  Others had to use a different usb to serial adapter to get it to work.
-Scott
-Scott
5 Replies 5
Scott Fella
Seems like you might have an issue with your cosole cable or your settings (9600 8-n-1).  You should see output from the APs console so try a different laptop and usb to serial adapter.
AP join to a vWLC depends if you have your vWLC setup properly.  From a wired laptop on the vlan the ap is on, can you ping the management interface of the vWLC and also the service port?  You should not have any connectivity between the management and the service port!!!! That is important.
Here is a doc to review:
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/99948-lap-notjoin-wlc-tshoot.html
-Scott
-Scott
Goga
Frequent Visitor
Frequent Visitor
Scott, thank you for answer. Cable was successfully checked with cisco 3745 router. After some manipulations with licences on vWLC my AP joined to a vWLC, but still not sending any information to console cable.
-Scott
-Scott
I only can tell you that the cables to go usb to serial works and the one I use now is this:
http://www.get-console.com/shop/en/usb-to-serial-cables/57-usb-serial-cable-rj45-180cm.html
Along with their AirConsole.  I'm not saying you need this, but try a different use to serial and hopefully you have another APti test console on too.
-Scott
-Scott
Goga
Frequent Visitor
Frequent Visitor
You were right. Another USB-to-Serial adapter shows output from my AP. Thank you!
