2602E wireless bridge
kumaran pathmanathan
Community Member
Hi Guys,
I will need to configure IOS (standalone) 2602E as access point as wireless bridge. When I try to disable 3 out of 4 antenna ports (only enable A) for wireless birding it won’t save I get white screen but if make changes on rest the setting I have no issues. Anyone know why is that happening?  I can make any changes expect disabling the antenna ports?
Kumaran
Sandeep Choudhary
Hi Kumaran,
Follow this post:
https://supportforums.cisco.com/thread/2244263
More.......................
About your issue, you better go for Aironet IOS configuratoin guide. It is the config guide for autonomouse mode.
Check this config guide for example:
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b.html
Check the config examples right here:
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_configuration_examples_list.html
Hope this helps.
Scott Fella
Just to add. Here is a good basic easy to follow guide for bridging.
https://supportforums.cisco.com/docs/DOC-16087
You also need to be comfortable in making changes using the CLI and not the GUI. v12.4 is more stable when using the GUI than v15.x.
-Scott
