2602i fail to boot after joining controller
gocarroll
Community Member
I have two 2602i that are no longer booting after they joined the controller and pulled the updated image.
from the console this is what I see during the boot process.
IOS Bootloader - Starting system.
flash is writable
FLASH CHIP:  Numonyx Mirrorbit (0089)
Xmodem file system is available.
flashfs[0]: 43 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31997952
flashfs[0]: Bytes used: 11590656
flashfs[0]: Bytes available: 20407296
flashfs[0]: flashfs fsck took 19 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: 4c:00:82:b9:84:f6
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-k9w8-mx.152-4.JA1/ap3g2-k9w8-mx.152-4.JA1"...###########################
File "flash:/ap3g2-k9w8-mx.152-4.JA1/ap3g2-k9w8-mx.152-4.JA1" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
flashfs[0]: flashfs fsck took 12 seconds.
Boot CMD: 'boot  flash:/ap3g2-k9w8-mx.152-4.JA1/ap3g2-k9w8-xx.152-4.JA1'
Loading "flash:/ap3g2-k9w8-mx.152-4.JA1/ap3g2-k9w8-xx.152-4.JA1"...################
At that point right there it just hangs. I let it sit overnight with no change.
Any ideas?
My controller is running software version 7.5.102.0
2 Accepted Solutions
Hi Gary ,
Your AP have autonomous image ap3g2-k9w7-tar.default.
You must convert this image to Lightweight image(k9w8) then try to join with WLC.
  • k9w7 – autonomous IOS
  • k9w8 – full lightweight IOS (this is what is bundled in the WLC .aes image, and is factory installed on “mesh” APs)
  • rcvk9w8 – lightweight recovery image – this is factory installed on lightweight APs, unless a “mesh” image is specified; it lacks radio firmware
How to convert:
http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
https://supportforums.cisco.com/docs/DOC-14960
Just to add... make sure you download one of these images to upload to your 2602i.  I usually still use the 12.4 rcv image, but you can try either one:
ap3g2-rcvk9w8-tar.124-25e.JA1.tar
http://software.cisco.com/download/release.html?mdfid=284362257&flowid=34153&softwareid=280775090&release=15.2.4-JB3&relind=AVAILABLE&rellifecycle=ED&reltype=latest
ap3g2-rcvk9w8-tar.152-4.JB3.tar
Your AP did have the correct image on it initially, but either the WLC image is corrupt or the transfer corrupted the AP image.  I usually would go in to ROMMON mode and delete the images and various other files, like error log's, to clean up the AP.
Example:
ap:delete flash:private-config
ap:delete flash:private-multiple-fs
The set command will also let you see what image the AP will boot from.
When you upload the new image, you should capture the output from the console as this helps figure out whats wrong.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
9 Replies 9
Sandeep Choudhary
Hi gary,
Paste the output of the command:
WLC: sh sysinfo
AP: sh inventory
also paste the boot process from AP.
Reagrds
I pasted the boot process for the AP in my original post.
The AP won't complete boot so there is no way for me to issue the "show inventory" command to it.
Here is the output of "show sysinfo" from the WLC:
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.5.102.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 7.0.112.21
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
System Name...................................... mng-dc-wlc1
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 10.147.76.4
Last Reset....................................... Software reset
System Up Time................................... 0 days 22 hrs 14 mins 59 secs
System Timezone Location......................... (GMT -7:00) Mountain Time (US and Canada)
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
--More-- or (q)uit
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +37 C
External Temperature............................. +26 C
Fan Status....................................... OK
State of 802.11b Network......................... Disabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 0
Number of Active Clients......................... 0
Burned-in MAC Address............................ F8:72:EA:EE:EF:60
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 50
Hi Garry
Please also update FUS on WLC.
Try to Reset the Device to Default Settings and then try again.
If you need to start over during the initial setup process, you can reset the access point to factory default settings.
##Resetting to Default Settings Using the MODE Button
#Follow these steps to reset the access point to factory default settings using the access point MODE button:
#Step 1 Disconnect power (the power jack for external power or the Ethernet cable for in-line power) from the access point.
#Step 2 Press and hold the MODE button while you reconnect power to the access point.
#Step 3 Hold the MODE button until the Status LED turns amber (approximately 1 to 2 seconds), and release the button. All access point settings return to factory defaults.
http://www.cisco.com/en/US/docs/wireless/access_point/12.4.25d.JA/Configuration/guide/scg12.4.25d.JA-chap4-first.html#wp1034993
or
https://supportforums.cisco.com/thread/2045805
Regards.
Sandeep
Hi Sandeep,
I updated FUS on the WLC and attempted the reset as described and this is the output I am getting from the AP now.
flash is writable
flashfs[0]: flashfs fsck took 21 seconds.
button is pressed, wait for button to be released...
button pressed for 28 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image tftp://255.255.255.255/ap3g2-k9w7-tar.default
examining image...
DPAA Set for Independent Mode
DPAA_INIT = 0x0
%Error opening tftp://255.255.255.255/ap3g2-k9w7-tar.default (connection timed out)ap:
Hi Gary ,
How to convert:
Example:
Scott
-Scott
Thank you both for your assistance. This seems to have done the trick for one of them. I am going through the process for the other one that was giving me issues.
Is there a way I can tell from the part number or serial number as to how these shipped?
The part number showing up on the box is AIR-CAP2602I-A-K9 and all of the serial numbers start with FGL.
Part number is what you look at.
CAP = capwap
SAP = Standalone Autonomous
-Scott
Excellent!
Thank you both again for your assistance.
