2702 AP for Survey mode
john1983mw09525
Hi all. I have a customer currently using Cisco 2702e with omni directional antennas. We are looking to replace some of these with directional antennas and therefore would like to survey.
I have surveyed before using Meraki which is really straight forward whenit comes to putting the AP into survey mode.
Is there a step by step guide on how to put a 2702e into survey mode? Is it done on the cli or the WLC?
Any help would be greatly appreciated.
Sandeep Choudhary
Here is the posts about to configure a Cisco AP for Site Survey:
https://thewlan.com.au/2016/09/27/configuring-a-cisco-ap-for-site-survey/
Dont forget to rate helpful posts
Hi Sandeep, I will give this a go. Thanks for your reply.
I additionally endorse to use a expert corporation. Site surveys want enjoy and a few precise hardware to get truly useful effects. You can do it your self, for example with the mentioned Ekahau suite for new page, but revel in in doing it is also very crucial.
