LAP-1142N dose not registered with vWLC 7-3-101-0
I know that this topic is repeated so many times but still i did not get any help out of them. I am really greatfull to all of you guys who are making efforts here to help out others.
My Scanerio is that i have connected vWLC (On Vmware WS) with Cisco 3750L3 switch and my GW is FW. I have created 2 VLANs (VLAN10 and VLAN20) respectivly. I have a DHCP and DNS server, installed on Windows Server 2012 (VMwere) with scopes of DHCP, one for VLAN10 and one for VLAN20. all my devices are connected with VLAN10 (10.1.1.0/24) and only AP is connected with VLAN20 (10.1.2.0/24). Configured IP Helper command under VLAN 20 so it is communication with VLAN 10 and all network.
AP is getting DHCP IP from windows DHCP server and can ping to vWLC but its not pinging to DNS server and DHCP server which is on VLAN 10.
and when im trying to get registered AP with vWLC ( 7-3-101-0), it does not get registered and showing below logs.
*Jul 14 22:37:19.005: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 14 22:37:19.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 14 22:37:19.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 14 22:37:19.014: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is not established.
*Jul 14 22:37:48.999: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2013 Max retransmission count reached!
*Jul 14 22:37:48.999: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 10.1.1.120 is reached.
*Jul 14 22:38:18.999: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.1.120:5246
*Jul 14 22:38:19.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 14 22:38:29.005: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 14 22:38:29.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 14 22:38:29.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
Please look into above and advise me...
18 Replies 18
Leo Laohoo
Post the complete output to the following commands:
  1. vWLC:  sh sysinfo;
  2. AP:  sh version; and
  3. AP:  sh ip interface brief
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.3.101.0
RTOS Version..................................... 7.3.101.0
Bootloader Version............................... 7.3.101.0
Emergency Image Version.......................... 7.3.101.0
Build Type....................................... DATA + WPS
System Name...................................... WLC1
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 10.1.1.120
System Up Time................................... 0 days 11 hrs 32 mins 36 secs
System Timezone Location.........................
Configured Country............................... AU - Australia
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
--More-- or (q)uit
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 00:0C:29:BE:43:EE
Maximum number of APs supported.................. 200
  1. AP:  sh version;
APa493.4c38.0b67#sh ver
Cisco IOS Software, C1140 Software (C1140-RCVK9W8-M), Version 12.4(21a)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 08-Jun-09 16:28 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
APa493.4c38.0b67 uptime is 10 hours, 56 minutes
System returned to ROM by reload
System image file is "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1142N-N-K9 (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FGL1620S4Y9
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from reload
LWAPP image version 3.0.51.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: A4:93:4C:38:0B:67
Part Number : 73-12836-04
PCA Assembly Number : 800-33767-04
PCA Revision Number : A0
PCB Serial Number : FOC16192EK0
Top Assembly Part Number : 800-33775-03
Top Assembly Serial Number : FGL1620S4Y9
Top Revision Number : A0
Product/Model Number : AIR-LAP1142N-N-K9
Configuration register is 0xF
APa493.4c38.0b67#
  1. AP:  sh ip interface brief
APa493.4c38.0b67#sh ip int br
Interface                        IP-Address           OK?         Method           Status            Protocol
GigabitEthernet0         10.1.2.50               YES          DHCP             up                    up
Current logs of AP:
*Jul 15 13:16:25.999: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.1.120:5246
*Jul 15 13:16:26.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 15 13:16:36.005: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 15 13:16:36.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 15 13:16:36.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 15 13:17:05.999: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2013 Max retransmission count reached!
*Jul 15 13:17:05.999: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 10.1.1.120 is reached.
*Jul 15 13:17:36.000: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.1.120:5246
*Jul 15 13:17:36.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 15 13:17:36.001: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 15 13:17:46.006: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 15 13:17:46.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 15 13:17:46.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 15 13:17:46.013: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is not established.
*Jul 15 13:18:16.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2013 Max retransmission count reached!
*Jul 15 13:18:16.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 10.1.1.120 is reached.
*Jul 15 13:18:45.999: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.1.120:5246
*Jul 15 13:18:46.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 15 13:18:56.005: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 15 13:18:56.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 15 13:18:56.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 15 13:19:25.999: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2013 Max retransmission count reached!
*Jul 15 13:19:25.999: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 10.1.1.120 is reached.
*Jul 15 13:19:55.999: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.1.120:5246
*Jul 15 13:19:56.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 15 13:20:06.005: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 15 13:20:06.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 15 13:20:06.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 15 13:20:36.001: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2013 Max retransmission count reached!
*Jul 15 13:20:36.001: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 10.1.1.120 is reached.
*Jul 15 13:21:06.000: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.1.120:5246
*Jul 15 13:21:06.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 15 13:21:06.001: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 15 13:21:16.006: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 15 13:21:16.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 15 13:21:16.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 15 13:21:16.014: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is not established.
*Jul 15 13:21:46.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2013 Max retransmission count reached!
*Jul 15 13:21:46.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 10.1.1.120 is reached.
*Jul 15 13:22:15.999: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.1.120:5246
*Jul 15 13:22:16.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 15 13:22:26.005: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 15 13:22:26.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 15 13:22:26.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 15 13:22:56.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2013 Max retransmission count reached!
*Jul 15 13:22:56.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 10.1.1.120 is reached.
*Jul 15 13:23:25.999: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.1.120:5246
*Jul 15 13:23:26.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 15 13:23:36.005: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 15 13:23:37.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 15 13:23:37.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 15 13:24:06.999: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2013 Max retransmission count reached!
*Jul 15 13:24:06.999: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 10.1.1.120 is reached.
*Jul 15 13:24:36.999: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.1.120:5246
*Jul 15 13:24:37.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 15 13:24:47.005: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 15 13:24:47.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 15 13:24:47.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 15 13:24:47.014: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is not established.
*Jul 15 13:25:17.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2013 Max retransmission count reached!
*Jul 15 13:25:17.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 10.1.1.120 is reached.
How many APs is the vWLC licensed for?
200 Access Points Supported
If the AP has an IP address, could the AP ping the Management IP Address of the vWLC?
Yes, AP can ping the vWLC management IP address 10.1.1.120
APa493.4c38.0b67#ping 10.1.1.120
Sending 5, 100-byte ICMP Echos to 10.1.1.120, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
APa493.4c38.0b67#
From Controller to AP:
(Cisco Controller) >ping 10.1.2.50
Send count=3, Receive count=3 from 10.1.2.50
On the AP, kindly try the command "capwap ap controller <Management IP address of the controller>".
This command does not support the ap:
APa493.4c38.0b67#capwap ap controller 10.1.1.120
% Invalid input detected at '^' marker.
APa493.4c38.0b67#
I tried this command but didnt get anything...
APa493.4c38.0b67#lwapp ap controller ip address 10.1.1.120
APa493.4c38.0b67#
APa493.4c38.0b67#
Current logs of AP:
*Mar 1 00:14:43.963: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 15 20:58:46.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 15 20:58:46.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 15 20:58:46.002: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is not established.
*Jul 15 20:59:15.999: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2013 Max retransmission count reached!
*Jul 15 20:59:15.999: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 10.1.1.120 is reached.
*Jul 15 20:59:45.999: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.1.120:5246
*Jul 15 20:59:46.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 15 20:59:56.007: %CAPWAP-3-ERRORLOG: Go join a lwapp controller
*Jul 15 20:59:56.007: %LWAPP-3-CLIENTERRORLOG: Set Transport AddressCalled
*Jul 15 20:59:56.015: %LWAPP-5-CHANGED: CAPWAP changed state to JOIN
*Jul 15 21:00:01.014: %LWAPP-3-CLIENTERRORLOG: Join Timer: did not recieve join response (controller - WLC1)
*Jul 15 21:00:01.014: %LWAPP-3-CLIENTERRORLOG: Set Transport AddressCalled
*Jul 15 21:00:01.015: %LWAPP-3-CLIENTERRORLOG: Set Transport Address: no more AP manager IP addresses remain
*Jul 15 21:00:01.015: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 15 20:59:56.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 15 20:59:56.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 15 20:59:56.002: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is not established.
*Jul 15 21:00:25.999: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2013 Max retransmission count reached!
*Jul 15 21:00:25.999: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 10.1.1.120 is reached.
*Jul 15 21:00:55.999: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.1.120:5246
*Jul 15 21:00:56.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 15 21:01:06.005: %CAPWAP-3-ERRORLOG: Go join a lwapp controller
*Jul 15 21:01:06.005: %LWAPP-3-CLIENTERRORLOG: Set Transport AddressCalled
*Jul 15 21:01:06.012: %LWAPP-5-CHANGED: CAPWAP changed state to JOIN
*Jul 15 21:01:11.012: %LWAPP-3-CLIENTERRORLOG: Join Timer: did not recieve join response (controller - WLC1)
*Jul 15 21:01:11.012: %LWAPP-3-CLIENTERRORLOG: Set Transport AddressCalled
*Jul 15 21:01:11.012: %LWAPP-3-CLIENTERRORLOG: Set Transport Address: no more AP manager IP addresses remain
*Jul 15 21:01:11.012: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 15 21:01:11.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 15 21:01:11.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 15 21:01:41.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2013 Max retransmission count reached!
*Jul 15 21:01:41.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 10.1.1.120 is reached.
Nothing is block on firewall... i can ping internet from AP
APa493.4c38.0b67#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 18/18/19 ms
APa493.4c38.0b67#
APa493.4c38.0b67#
APa493.4c38.0b67#ping www.google.com
Translating "www.google.com"...domain server (10.1.1.99) [OK]
Sending 5, 100-byte ICMP Echos to 172.217.25.36, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/17/18 ms
APa493.4c38.0b67#
i can ping firewall IP
Sending 5, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
APa493.4c38.0b67#
Now having certificate issue
*Jul 15 22:57:31.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 15 22:57:41.004: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 15 22:57:41.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 15 22:57:41.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 15 22:57:41.020: %LWAPP-3-CLIENTERRORLOG: Peer certificate verification failed
*Jul 15 22:57:41.020: %CAPWAP-3-ERRORLOG: Certificate verification failed!
*Jul 15 22:57:41.020: DTLS_CLIENT_ERROR: ../capwap/capwap_wtp_dtls.c:326 Certificate verified failed!
*Jul 15 22:57:41.020: %DTLS-4-BAD_CERT: Certificate verification failed. Peer IP: 10.1.1.120
*Jul 15 22:57:41.020: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 10.1.1.120:5246
*Jul 15 22:57:41.020: %DTLS-3-BAD_RECORD: Erroneous record received from 10.1.1.120: Malformed Certificate
*Jul 15 22:57:41.021: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.1.120:5246
*Jul 15 22:57:41.021: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 3 combination.
Finally i registered the AP with vWLC... :)
but it dose not broadcast ssid..AP is in default group
