2802AP join issue
ittechk4u1
Level 7
Level 7
Hello Experts,
I having issue with one AP, whcih is not joing to WLC (version 8.5.151.0), rest more then 30 APs are joined.
Here are logs from AP:
Discovery response from MWAR ''running version 0.0.0.0 is rejected.
Failed to decode discovery response.
CAPWAP SM handler: Failed to process message type 2 state 2.
Failed to handle capwap control message from controller - status 4
Thanks in advance
7 Replies 7
Sandeep Choudhary
Paste the output of these commands:
sh syinfo from WLC
show time form WLC
Is AP getting enough power ? (either via PoE or power injector)
Dont forget to rate helpful posts
Here are the output:
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.151.0
RTOS Version..................................... 8.5.151.0
Bootloader Version............................... 8.3.15.177
Emergency Image Version.......................... 8.3.143.0
OUI File Last Update Time........................ Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... WLC1
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.2170
Redundancy Mode.................................. SSO
IP Address....................................... 192.168.80.1
IPv6 Address..................................... ::
System Up Time................................... 0 days 13 hrs 35 mins 43 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
--More-- or (q)uit
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... FR - France
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... 10 to 38 C
Internal Temperature............................. +23 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 5
Number of Active Clients......................... 64
OUI Classification Failure Count................. 294
Memory Current Usage............................. 9
Memory Average Usage............................. 9
CPU Current Usage................................ 0
CPU Average Usage................................ 0
Flash Type....................................... Compact Flash Card
Flash Size....................................... 1073741824
Burned-in MAC Address............................
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 1500
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1/SHA2
Licensing Type................................... RTU
(WLC1) >show time
Time............................................. Fri Feb 7 12:45:18 2020
Country code and software version are ok.
How about the power ? Is it getting enough power or  ?
We are using PoE and AP is getting full power (26.1W )
Ok then it must be buggy CSCvf71074/CSCvh85082.
Raise a TAC case and ask about the solution or RMAed it.
Ok i will check with my supplier. Thanks
Scott Fella
Try to search the error and look at what others have had to do. There are bugs related to that specific error you posted. This is just one.
https://quickview.cloudapps.cisco.com/quickview/bug/CSCvf71074
-Scott
