2802i flashing green + solution
patoberli
Hi All
I had a brand new 2802i which had an issue with booting up. It only showed the green LED flashing. After attaching a console and booting it again, I saw that it landed in ROM mode. I might have accidently unplugged it while it was booting up the first time, because I needed to replace the PoE adapter.
In any case, here in the Japanese Cisco forum I found the solution:
https://supportforums.cisco.com/ja/document/13217331
Thanks @kumatsum
u-boot >> boot
The boot hangs at the initialization process and doesn't proceed until one connects a console and presses enter. It will fail though, as it can't find the recovery image (nor could I locate it on the Cisco download site).
u-boot>> boot
Starting board initialization process. Proceed? [y/N]:
Aborting board initialization...
u-boot>> boot
Starting board initialization process. Proceed? [y/N]: y
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 172.22.177.16
Using egiga2 device
TFTP from server 0.0.0.0; our IP address is 172.22.177.16; sending through gateway 172.22.177.254
Filename 'board_init_barbados2k.img'.
Load address: 0x2000000
Loading: T T T T T T T T T T
Retry count exceeded; starting again
mvEgigaInit: egiga1 mvNetaPortEnable failed (error)
mvEgigaInit: egiga1 failed
Showing the configured environment variables and showing the faulty bootcmd.
u-boot>> printenv
BOOT=part1
CASset=max
ENABLE_BREAK=1
FACTORY_RESET=0
MALLOC_len=5
MANUAL_BOOT=0
MEMORY_DEBUG=0
MPmode=SMP
autoload=yes
baudrate=9600
bootcmd=boardinit <<<<<
bootdelay=3
bootfile=board_init_barbados2k.img
cacheShare=no
disaMvPnp=no
eeeEnable=no
enaClockGating=no
enaCpuStream=no
enaFPU=yes
enaMonExt=no
enaWrAllo=no
eth1addr=00:50:43:xx:xx:xx
eth1mtu=1500
eth2addr=00:50:43:xx:xx:xx
eth2mtu=1500
ethact=egiga2
ethaddr=00:50:43:xx:xx:xx
ethmtu=1500
ethprime=egiga2
image_name=part.bin
initrd_high=0xffffffff
limit_dram_size=yes
loadaddr=0x02000000
loads_echo=0
mtddevname=fs
mtdids=nand0=armada-nand
mtdparts=mtdparts=armada-nand:1m(oops),1m(reserved),-(fs)
nandEcc=nfcConfig=4bitecc
netretry=yes
partition=nand0,2
pcieTune=no
pexMode=RC
stderr=serial
stdin=serial
stdout=serial
yuk_ethaddr=00:00:00:xx:xx:xx
Environment size: 894/65532 bytes
Correcting the false bootcmd and saving and rebooting.
u-boot>> setenv bootcmd nandboot
u-boot>> saveenv
u-boot>> boot
Here with console output.
u-boot>> saveenv
Saving Environment to SPI Flash...
Erasing SPI flash....Writing to SPI flash.....done
u-boot>> boot
Creating 1 MTD partitions on "nand0":
0x000000200000-0x000010000000 : "mtd=2"
UBI: attaching mtd1 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: attached mtd1 to ubi0
UBI: MTD device name: "mtd=2"
UBI: MTD device size: 254 MiB
UBI: number of good PEBs: 2024
UBI: number of bad PEBs: 8
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 8
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 2024
UBI: number of PEBs reserved for bad PEB handling: 20
UBI: max/mean erase counter: 198/104
UBIFS: mounted UBI device 0, volume 0, name "part1"
UBIFS: mounted read-only
UBIFS: file system size: 65646592 bytes (64108 KiB, 62 MiB, 517 LEBs)
UBIFS: journal size: 8888320 bytes (8680 KiB, 8 MiB, 70 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: LZO
UBIFS: reserved for root: 0 bytes (0 KiB)
Loading file 'part1/part.bin' to addr 0x02000000 with size 18584351 (0x011b931f)...
Done
SF: Detected N25Q32A with page size 64 KiB, total 4 MiB
Checking image signing.
This could take up to 40 seconds. Please wait...
Image signing verification success, continue to run...
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Barbados Firmware Image
Created: 2016-09-27 10:38:44 UTC
Image Type: ARM Linux Multi-File Image (uncompressed)
Data Size: 18583343 Bytes = 17.7 MiB
Load Address: 00008000
Entry Point: 00008000
Contents:
Image 0: 4033488 Bytes = 3.8 MiB
Image 1: 14534391 Bytes = 13.9 MiB
Image 2: 15447 Bytes = 15.1 KiB
Verifying Checksum ... OK
## Loading init Ramdisk from multi component Legacy Image at 02000000 ...
## Flattened Device Tree from multi component Image at 02000000
Booting using the fdt at 0x031b5318
Loading Multi-File Image ... OK
OK
Loading Device Tree to 00ff9000, end 00fffc56 ... OK
Starting Device Tree update ('fdt_skip_update' = no)
Limit DDR size at 3GB due to power of 2 requirement of Address decoding
Updating device tree successful
Starting kernel ...
[01/01/1970 00:00:05.2900] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
[01/01/1970 00:00:05.4000] Memory: 1016064K/1048576K available (5584K kernel code, 362K rwdata, 2412K rodata, 343K init, 465K bss, 32512K reserved, 0K highmem)
[01/01/1970 00:00:05.5700] CPU1: Booted secondary processor
[01/01/1970 00:00:05.6300] buginf tty flushing thread started, ttyport=bf0e7000
[01/01/1970 00:00:05.7500] m25p80 spi1.0: found n25q032a, expected n25q032
[01/01/1970 00:00:05.9700] i2c i2c-0: of_i2c: modalias failure on /soc/internal-regs/i2c@11000/chan2
[01/01/1970 00:00:07.0800] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 20, need 32
[*01/01/1970 00:00:07.2318] buginf() enabled.
17 Replies 17
DivakaranV
I wanted to reflash and format partition to reload the image. The reason is that I have 4800 in capwap mode and trying to migrate to mobility and it say same issue or file corrupted. I tried 8.10.185 and lower versions. I have 8.7.106 currently. I am thinking of downgrading the image from 8.7.106 to other version reflash and format partition and proceed.I tried many other images different version checked the checksum with md5sum and sha512.
Because of an expired certificate problem, you must use 8.10.185.0 or later. You could also adjust the date/time before the downgrade to a date around November 2022.
Anyway, unless you have exactly this error, I suggest you open a fresh thread for the problem.
AJarvy
This was clutch. I was hitting the same "board selection" prompt. My bootcmd was good, but I noticed my bootfile was missing. Added the bootfile for my board and it fixed the problem.
