2802i flashing green + solution
patoberli
Hi All
I had a brand new 2802i which had an issue with booting up. It only showed the green LED flashing. After attaching a console and booting it again, I saw that it landed in ROM mode. I might have accidently unplugged it while it was booting up the first time, because I needed to replace the PoE adapter.
In any case, here in the Japanese Cisco forum I found the solution:
https://supportforums.cisco.com/ja/document/13217331
Thanks @kumatsum
u-boot >> boot
The boot hangs at the initialization process and doesn't proceed until one connects a console and presses enter. It will fail though, as it can't find the recovery image (nor could I locate it on the Cisco download site).
u-boot>> boot
Starting board initialization process. Proceed? [y/N]:
Aborting board initialization...
u-boot>> boot
Starting board initialization process. Proceed? [y/N]: y
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 172.22.177.16
Using egiga2 device
TFTP from server 0.0.0.0; our IP address is 172.22.177.16; sending through gateway 172.22.177.254
Filename 'board_init_barbados2k.img'.
Load address: 0x2000000
Loading: T T T T T T T T T T
Retry count exceeded; starting again
mvEgigaInit: egiga1 mvNetaPortEnable failed (error)
mvEgigaInit: egiga1 failed
Showing the configured environment variables and showing the faulty bootcmd.
u-boot>> printenv
BOOT=part1
CASset=max
ENABLE_BREAK=1
FACTORY_RESET=0
MALLOC_len=5
MANUAL_BOOT=0
MEMORY_DEBUG=0
MPmode=SMP
autoload=yes
baudrate=9600
bootcmd=boardinit <<<<<
bootdelay=3
bootfile=board_init_barbados2k.img
cacheShare=no
disaMvPnp=no
eeeEnable=no
enaClockGating=no
enaCpuStream=no
enaFPU=yes
enaMonExt=no
enaWrAllo=no
eth1addr=00:50:43:xx:xx:xx
eth1mtu=1500
eth2addr=00:50:43:xx:xx:xx
eth2mtu=1500
ethact=egiga2
ethaddr=00:50:43:xx:xx:xx
ethmtu=1500
ethprime=egiga2
image_name=part.bin
initrd_high=0xffffffff
limit_dram_size=yes
loadaddr=0x02000000
loads_echo=0
mtddevname=fs
mtdids=nand0=armada-nand
mtdparts=mtdparts=armada-nand:1m(oops),1m(reserved),-(fs)
nandEcc=nfcConfig=4bitecc
netretry=yes
partition=nand0,2
pcieTune=no
pexMode=RC
stderr=serial
stdin=serial
stdout=serial
yuk_ethaddr=00:00:00:xx:xx:xx
Environment size: 894/65532 bytes
Correcting the false bootcmd and saving and rebooting.
u-boot>> setenv bootcmd nandboot
u-boot>> saveenv
u-boot>> boot
Here with console output.
u-boot>> saveenv
Saving Environment to SPI Flash...
Erasing SPI flash....Writing to SPI flash.....done
u-boot>> boot
Creating 1 MTD partitions on "nand0":
0x000000200000-0x000010000000 : "mtd=2"
UBI: attaching mtd1 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: attached mtd1 to ubi0
UBI: MTD device name: "mtd=2"
UBI: MTD device size: 254 MiB
UBI: number of good PEBs: 2024
UBI: number of bad PEBs: 8
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 8
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 2024
UBI: number of PEBs reserved for bad PEB handling: 20
UBI: max/mean erase counter: 198/104
UBIFS: mounted UBI device 0, volume 0, name "part1"
UBIFS: mounted read-only
UBIFS: file system size: 65646592 bytes (64108 KiB, 62 MiB, 517 LEBs)
UBIFS: journal size: 8888320 bytes (8680 KiB, 8 MiB, 70 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: LZO
UBIFS: reserved for root: 0 bytes (0 KiB)
Loading file 'part1/part.bin' to addr 0x02000000 with size 18584351 (0x011b931f)...
Done
SF: Detected N25Q32A with page size 64 KiB, total 4 MiB
Checking image signing.
This could take up to 40 seconds. Please wait...
Image signing verification success, continue to run...
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Barbados Firmware Image
Created: 2016-09-27 10:38:44 UTC
Image Type: ARM Linux Multi-File Image (uncompressed)
Data Size: 18583343 Bytes = 17.7 MiB
Load Address: 00008000
Entry Point: 00008000
Contents:
Image 0: 4033488 Bytes = 3.8 MiB
Image 1: 14534391 Bytes = 13.9 MiB
Image 2: 15447 Bytes = 15.1 KiB
Verifying Checksum ... OK
## Loading init Ramdisk from multi component Legacy Image at 02000000 ...
## Flattened Device Tree from multi component Image at 02000000
Booting using the fdt at 0x031b5318
Loading Multi-File Image ... OK
OK
Loading Device Tree to 00ff9000, end 00fffc56 ... OK
Starting Device Tree update ('fdt_skip_update' = no)
Limit DDR size at 3GB due to power of 2 requirement of Address decoding
Updating device tree successful
Starting kernel ...
[01/01/1970 00:00:05.2900] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
[01/01/1970 00:00:05.4000] Memory: 1016064K/1048576K available (5584K kernel code, 362K rwdata, 2412K rodata, 343K init, 465K bss, 32512K reserved, 0K highmem)
[01/01/1970 00:00:05.5700] CPU1: Booted secondary processor
[01/01/1970 00:00:05.6300] buginf tty flushing thread started, ttyport=bf0e7000
[01/01/1970 00:00:05.7500] m25p80 spi1.0: found n25q032a, expected n25q032
[01/01/1970 00:00:05.9700] i2c i2c-0: of_i2c: modalias failure on /soc/internal-regs/i2c@11000/chan2
[01/01/1970 00:00:07.0800] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 20, need 32
[*01/01/1970 00:00:07.2318] buginf() enabled.
17 Replies 17
brandorsens
I had this exact problem on three 3802i APs and this solution saved my bacon.
Thanks!
JPLAURORA
As always the Cisco Support Communities is the first stop to check when having an issue.  I had this exact problem on a Cisco 3802I AP and performed the steps from the U-Boot CLI and the AP rebooted with no further issues.
Thank You for posting the solution!!
James
Saravanan Lakshmanan
its yet to get fixed.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvd54349
Help  | Feedback Feedback
2800/3800 not booting up "Error: Unable to download image board_init_barbados3k.img"
CSCvd54349
Description
Symptom:
COS APs don't boot up when out of the box. Console outputs show u-boot loads but error message comes up as:
Using egiga2 device
TFTP from server x.x.x.x; our IP address is x.x.x.x
Filename 'board_init_barbados3k.img'.
Loading: *
TFTP error: 'Access violation.' (4)
Starting again
Using egiga2 device
Loading: *
Starting again
Abort
Error: Unable to download image board_init_barbados2k.img // For 2800 APs
Error: Unable to download image board_init_barbados3k.img // For 3800 APs
This occurs because the AP is trying to boot from a tftp server and is not falling back to booting from flash when not found. A command must be run to tell the AP to load its image from flash instead.
Conditions:
N/A
Workaround:
From u-boot, run the commands:
u-boot>> set bootcmd nandboot
u-boot>> saveenv
u-boot>> boot
Was the description about this Bug Helpful?
(0)
Details
Last Modified:
Dec 19,2017
Status:
Open
Severity:
3 Moderate
Product:
(1)
Cisco Aironet 3800 Series Access Points
Known Affected Releases:
(1)
all
roger.t01
I could configure bootcmd by above commands but on ever reload the ap stops at,
BootROM - 1.78
Booting from SPI flash, Secure mode
BootROM: RSA Public key verification PASSED
BootROM: CSK block signature verification PASSED
BootROM: Boot header signature verification PASSED
BootROM: Box ID verification PASSED
BootROM: JTAG is disabled
General initialization - Version: 1.0.0
Detected Device ID 6920
Master bootloder version 1.1e
Please choose one of the following boards:
1. 3K
2. 2K (new)
3. 2K (proto)
4. Milos
5. 2KH
6. 3KVE (v-sku)
7. 3KH/3KA
init>>
What can be done to skip this part
Try option 1 (no guarantee!) and see if it boots. But I guess your AP requires a re-flash through TAC.
I too have the same problem on a 3800 AP the above mention CLI after done allowed me to move further along in the boot process and had the AP attempting to download the needed software from WLC. However never progressed to a registered state in WLC. Any updates on resolve for this problem? Thanks
I am left with a " init>> " prompt and option to choose the following boards:
1. 3K
2. 2K (new)
3. 2K (proto)
4. Milos
5. 2KH
6. 3KVE (v-sku)
7. 3KH/3KA
init>>
after selecting option 1 and going through processes I was held up on the CLI of WAP asking for username and password?
my error message now is:
(write) Unable to open I2C device interface (/dev/act2) for ACT2 (file = -1)
(ACT2Boot) Hardware is NOT Cisco (c) authentic :-(
System will reboot in 10 seconds
WAP reboots and I am prompted once again to choose from the following boards.
In this case you best RMA it. You have 10 years hardware warranty on it and I think that would include your error.
In my case the AP was working again after the I outlined in my first post.
Cisco4Avanir
Hi Team,
I am having this problem in AP3802i. After I have changed the boot command bootcmd=nandboot,  still having the boot image failure issues
u-boot>> printenv
BOOT=part2
CASset=max
ENABLE_BREAK=1
FACTORY_RESET=2
MALLOC_len=5
MANUAL_BOOT=0
MEMORY_DEBUG=0
MPmode=SMP
autoload=yes
baudrate=9600
bootargs=console=ttyS0,9600 activepart=part2 activeboot=0 bootver=0x106 boardid=0x20 nss_emac_map=0x3 wired0=0 phy0=aq nfcConfig=4bitecc mtdparts=armada-nand:1m(oops),1m(reserved),-(fs) ubi.mtd=fs wired1=1 phy1=mvl
bootcmd=nandboot
bootdelay=3
cacheShare=no
consoledev=ttyS0
disaMvPnp=no
eeeEnable=no
enaClockGating=no
enaCpuStream=no
enaFPU=yes
enaMonExt=no
enaWrAllo=no
eth1addr=00:50:43:5d:4e:18
eth1mtu=1500
eth2addr=00:50:43:5d:ab:18
eth2mtu=1500
ethact=egiga2
ethaddr=00:50:43:ab:4e:18
ethmtu=1500
ethprime=egiga2
filesize=607A00
image_name=part.bin
limit_dram_size=yes
loadaddr=0x02000000
loads_echo=0
mtddevname=fs
mtddevnum=2
netretry=yes
nss_emac_map=0x3
partition=nand0,2
pcieTune=no
pexMode=RC
stderr=serial
stdin=serial
stdout=serial
wired0=0
yuk_ethaddr=00:00:00:EE:51:81
Environment size: 1154/65532 bytes
u-boot>> boot
Unmounting UBIFS volume part2!
UBI: mtd1 is detached from ubi0
UBI: max/mean erase counter: 21/1
UBIFS: mounted UBI device 0, volume 1, name "part2"
Loading file 'part2/part.bin' to addr 0x02000000 with size 6322688 (0x00607a00)...
Done
Image signing verification failure, not allowed to run...
u-boot>>
Then you might have a broken flash or image. There are some image recovery procedures, but you're probably quicker making an RMA for the AP.
Patoberli,
would you mind share these image recovery procedures?
Dan
Hi Dan
Not sure what you need, they are described in my first post.
Maybe your AP is just broken? Don't forget, most models have 10 years of warranty.
Dan4171
patoberli
Dante
Can you elaborate on your specific problem? What is the AP doing while booting it up?
Hi Patoperli can you share the image recovery procedure pls for 4800 ap
